Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 99
    Administrator
    Devilfish's Avatar
    Feb 2008
    Default Guide: Connecting your Dreambox to the Internet
    Making Your Dreambox Wireless
    There seems to be an ever increasing want to connect your dreambox to the internet. New images are being created with Addon menus which allow you to download plugins, emu, games, etc. direct to your dreambox. Your dreambox just needs to be connect to the internet!
    Via Router
    This is by far the easiest method of connecting it to the internet.
    First of all, we'll assume that you can already connect to your box via FTP via a crossover cable. If you can't, you might want to read up on that before attempting this.
    Now, what we'll need is...
    • Ethernet cable (crossover or patch)
    • Router
    • Modem
    We'll also assume that you have a router (wireless or not) and that your modem is connected to the 'Internet' or 'WAN' port.
    If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don't need to change any settings on your router or PC.
    Over to the dreambox. Navigate to the networking page on your dreambox.
    Setup -> Expert Setup -> Communication Setup
    There is a section in this page called 'Default Gateway'. You need to put the ip address of your router in there. It's usually 192.168.0.1, 192.168.1.1 or 192.168.2.1 (depending on the manufacturer). You can find out my opening your browser and typing one of the ip addresses in to the address bar. If you are presented with the router config page or a box asking for a username and password, this is the ip address for your router.
    If you have enabled DHCP support on your router, all you have to do it tick the DHCP box in this page, save settings, reboot box and that's that. The router will automatically assign the dreambox an ip address and it's now connected to the internet.
    If you don't have DHCP enabled, you will need to assign a static ip address to the dreambox manually. This needs to be in the same subnet as your router ip address. The subnet is the first 3 ranges of the ip address, i.e. 192.168.1.*. Make the last range anything between 2-254 as long as another PC or laptop on your network doesn't have that ip address. Each device must have it's own ip address. Save settings and reboot box and you should be connected.
    Via Wireless
    There are devices which can make any ethernet equipped device into a wireless device. They are called a 'Wireless Ethernet Bridge' or a 'Wireless Gaming Adapter'. The settings on the dreambox are exactly the same as if you're using a router on it's own. The gateway to the internet is still via your wireless router so the router ip address needs to go into the 'Default Gateway' section. You're best getting these devices on Ebay or at a website like broadbandstuff.co.uk. You will need to follow the instructions that come with the device to connect it to your own network.
    Via Modem
    If you have a spare modem lying about, clone or original, you can use this to connect directly to the internet without any wireless devices or routers.
    First of all, you will need to connect a PC or laptop to the modem to find out it's ip address. This ip address goes into the 'Default Gateway' section of the network settings page on your dreambox. Also enable DHCP on your dreambox. This is all that's needed.
    So, now you have no excuse to get your dreambox connected to the internet. There are loads of great plugins out there that could enhance your dreambox experience. Some examples include an RSS Newsreader (for viewing RSS feeds from your favourite website or even the forum if the RSS option is enabled, DreamNetCast Internet Radio (listen to your favourite internet radio station) or Dream Weather X (gives you access to weather information).
    I hope this has helped you and good luck!
  2. The Following 3 Users Say Thank You to Devilfish For This Useful Post:
  3. #2
    Apr 2008
    Default Thanks for the instructions
    I'm new to this and appreciate the help.
    Administrator
    Devilfish's Avatar
    Feb 2008
    No worries guys! That's why we're here!
    Any problems, just ask!
  5. The Following User Says Thank You to Devilfish For This Useful Post:
  6. #4
    Apr 2008
    Default Thank you
    thank you this is so useful for somebody new like me
  7. #5
    Apr 2008
    Default help please
    Do you leave the dreambox connected to the TV and then connect to the internet?
  8. The Following User Says Thank You to ash1809 For This Useful Post:
  9. #6
    Apr 2008
    Smile Thanx
    Been wanting to do this for a while so I dont have to rely on others!
    Feel confident to do it now
    CHEERS
  10. The Following User Says Thank You to big e For This Useful Post:
  11. #7
    Administrator
    Devilfish's Avatar
    Feb 2008
    My dreambox is always connected to my TV and always connected to a wireless bridge.
    So I can connect to the dreambox using my main PC upstairs which is connected to my router and I can connect via my wireless laptop as well.
    I can also stream llive pictures via the laptop too.
  12. The Following User Says Thank You to Devilfish For This Useful Post:
  13. #8
    Top Poster jake1970's Avatar
    Apr 2008
    surrey
    many thanks learning already
    cheers
    what leads do i need to connect dreambox 500c to router and pc ?and do i need to have both leads conected to add image ,i think i might need a real idiots guide to this
  14. #9
    Administrator
    Devilfish's Avatar
    Feb 2008
    This thread explains what cables are required for the different methods.
    http://www.digital-kaos.co.uk/forums...ead.php?t=1307
  15. #10
    Apr 2008
    Huddersfield
    Thanks kaos, this site has been a godsend for me and I only found it after googleing for a fix. This is just the sort of thing that newbies need.
    Thanks again
    Harry
  16. #11
    Apr 2008
    Default cheers
    im new to all this but this guide was soo easy to follow.
    got no channels at the moment though!!
  17. #12
    Apr 2008
    Once this is done, can you auto-update via internet & if so how?
  18. #13
    Mar 2008
    Quote Originally Posted by ivordel View Post
    That depends what you mean by auto update. On uk cable the key auto update function has nothing to do with the internet.
    Most images do have a menu option to download cams, addons, games, software updates from the internet yes.
    IMHO if you have a router you need to connect the dreambox to it. The dreambox can then access the internet and you can access the dreambox from your PC/laptop
  19. #14
    May 2008
    Default Thanks mate
    nice post. I'm looking to connect my db via my laptop.
  20. #15
    Administrator
    Devilfish's Avatar
    Feb 2008
    Quote Originally Posted by choleban View Post
    Maybe this is where you want to look at.
    http://www.dreamboxtips.com/how-to-c...ox-to-your-pc/
