Results 1 to 7 of 7
    Fec001's Avatar
    Default Siemens PPD 1.2 Hot start problem?
    Hi!
    Mechanics ask me to repair hot start error in siemens PPD. As I know there is no "problem" with start maps in PPD software.
    DK Veteran mishu_b's Avatar
    Land of Choice!
    it can be solved from sw as well, if the complete mechanical system is OK.
    Fec001's Avatar
    It has got timing belt changed so maybe that is the source of the problem.
    Land of Choice!
    first be sure that the complete mechanical system is 100% OK.
    usually the last thing for this is to mod the sw in order to fix the HotStart
    Apr 2012
    Wonderland
    i know 140cv ppd1.2 have this problem also
    ProTuner since 1999
    Jul 2014
    If it was from the change of the timing belt probably you would have problem not only with the hot start. But mates are right, check all the mechanics before looking for software solution. Good luck!
    Fec001's Avatar
    mechanics readjust "shafts timing", all seems fine now. Thank you for infos!!!!
