This is verry strange ussualy this cars don't have problem with hot start ,are you shure all is fine like injector are the keep the pressure , are all sensors are right .
I have one similar problem before time and when the engine go over 70 degreses one or two of the injector (i am not sure how many ) go to make problems ,they start to allow a lot of the fuel from the ruturning lines and the pressure go down and the car start verry hard , but you need to see everything .
Make good diagnostic after 60 degreses when start to make this problems and watch what is happened :
-are the pressure in reil is enought
-are all sensor work correct
-how start to push the fuel in mg
you need to be sure - i that the all components work properly
