Results 1 to 1 of 1
    spiridonas's Avatar
    Default Audi A6 1.8T DTC remove
    Hi guys i have this problem with Audi a6 1.8T the fault code error is
    17953/p1545 Throttle Valve Controller the fault is Permanent and i can't erase i replace and throtle valve but the fault still exist.
    I read the memory 27c1024 outsite but i see in ecu base adapter memory with other chip insite.
    The ecu is tuned but working untill now fine
    Please can remove this fault error .
    Many thanks in advance
