Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Fr
    Hi I tested today but now I don't have crank and the key is not recognized at all.
    Before it tell me key 1 in ignition now is key not recognized .
    I will order some pcf9735 and try to program new pcf ,perhaps the key is bugging .
    What do you think ? I checked the neutral park if present and ok next I want to take new wire from ews to dme and test perhaps some parasites ?
  2. #17
    bram380's Avatar
    Indonesia +628153111774
    Car don't crank:
    -Fuse to EWS problem
    -Key problem
    -Ring antena problem
    -P/N switch problem
    -EWS problem
  3. The Following User Says Thank You to bram380 For This Useful Post:
    Freezzby (19th January, 2016)
  4. #18
    cjawahir's Avatar
    T&T
    try this file if not work make new key for position 1 , or do as Bram said .
    cj
  5. The Following User Says Thank You to cjawahir For This Useful Post:
  6. #19
    Fr
    Thanks guys received today the pcf's and added new key in 4 location but also no crank .
    For ews I tried spare one virgin so same.
    I will try key 1 file if not work I will take the time to inspect this and update you guys .
  7. #20
    Fr
    Today decided to take a look to the E53 and started by bypassing the ews to see if will crank and guess what - the sphere ews was faulty and the original too ...
    So I will go tomorrow to recover one but I think this was the problem .
    I continued the tests just in case : Ring antenna ok ,P/N switch ok , fuse ok and for key I suppose ok also I can id it with carprog or tag key .
    My problem was thinking the ews I have was ok ,I ordered a ews test tool ,it will serve for next time.
  8. #21
    Oct 2015
    What tool did you use to read the original ews?
    Only because occasionally when i use ak90 I get this no start problem after making a key.
    The cause of the problem is from small pieces of metal that short out the legs on chip after scraping the lacquer off.
    I just spray with some electrical cleaner and scrub it with a tooth brush, works every time.
