Results 1 to 11 of 11
    Shmortz's Avatar
    in the middle of nowhere
    Default Peugeot 307 SID803 EGR off
    I need proper EGR off solution for SID803, here is dump from micro
    here
    your file with egr off,let your tool correct the check sum
    Shmortz's Avatar
    thanks, I'll try and report!
    Shmortz's Avatar
    your dump is not correct, it is a try to remove fap but without switch...
    carmageddon's Avatar
    Italy
    Quote Originally Posted by Shmortz View Post
    hysteresis control : 55A80 and 55AA0, set to zero
  6. The Following User Says Thank You to carmageddon For This Useful Post:
    Shmortz (12th November, 2014)
    here
    tested 100% only you need to correct checksum
  8. The Following User Says Thank You to smt For This Useful Post:
  9. #7
    Shmortz's Avatar
    Quote Originally Posted by carmageddon View Post
    only those 2 adresses or from first to last set to zero?
    Quote Originally Posted by smt View Post
    I did FAP and EGR with more corrections suggested from another user and car is OK for now, chk is corrected with writing...
  10. #8
    Italy
    your first post dont say that you need dpf-fap off and i do only egr.
    dpf-fap off only pm
  11. #9
    Shmortz's Avatar
    Yes, this is true. Then it turned out that there are problems with FAP and found a way to remove both.
  12. #10
    Apr 2016
    Italy
    Please , help me I need a full back up for a Peuugeot 307 2.0 Hdi with this features : HW:9655041480 ,SW:9655474580 .
  13. #11
    Act Tuning's Avatar
    Sep 2016
    Around
    Post full info of the ecu,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
