godfathertwo (6th August, 2022)
Order cheapest kessy that I've could find. 40 euro
Did not care about last letter in part number, new kessy is 433mhz and car originally had 315mhz. Add kessy by vcds and pin, add new generated remotes from Xhorse 03-08 touareg 433mhz - kessy was from touareg, so with cayenne remotes , they did not worked - i am guessing due to fact this type and part number kessy was used only in touareg . And after 6 hours of trials and errors - car started and remotes were finally working.
VCDS instruction on kessy changing and key programming are not 100% correct.
I could not find anywhere any info about this, so here it is. Hope that any other people will not struggle on the kessy programming like I did. And YES it can be done "redneck" way" - 433mhz instead 315mhz and part number does't matter as far its the same version - keyless / no keyless. Siemens For siemens, not siemens for continental. etc.
Xhorse save my day, all over for all 3 kessy module that i had , ive made like 40 remotes before ive found what was going on with the car , and in the end found right one for working kessy
End of story. Happy ending.
Regards Oktawian
