Results 1 to 7 of 7
    Jul 2012
    Montreal, Canada
    Default 1999 VOLVO S80 CEM AND ECU SYNCHRONIZATION
    Is there someone who could check the synchronization between CEM and ECU? The problem is sometimes when the engine is running instrument cluster lost the RPM, Speed, Temperature and trip odometer and if you turn it off no doesn't start after until you disconnect the battery. Also there is from time to time I hear a clicking noise from CEM and no start again. Something block the Power Train CAN bus.
    Any ideas?
    heteromies
    Guest
    Quote Originally Posted by 112005 View Post
    Any ideas?
    Here fixed sychronization file. But i don't know is that your problem. But synchrozation was wrong. Test and use fix if helped. Use your own risk!
  3. The Following User Says Thank You to heteromies For This Useful Post:
    112005 (12th November, 2014)
    antwnhszr's Avatar
    macedonia is greek....
    saerch here on the forum for repair dah vovlo and do you understand emmediately....
    regard's
    Aug 2011
    Quote Originally Posted by antwnhszr View Post
    regard's
    clean blue gel around MCU and resolder MCU (if you have microscope you will be able to see the problem)
    regards
    Jul 2012
    Montreal, Canada
    Which MCU you are pointing (CEM, ECU or Instrument cluster)?
    It sounds like a software problem I have replaced already the CEM and ECU with transfer of data.
    Aug 2011
    Instrument cluster
  8. The Following User Says Thank You to pipina For This Useful Post:
    112005 (14th November, 2014)
  9. #7
    Jul 2012
    Montreal, Canada
    So far the car is running well now with synced ECU and replaced ECU and CEM.
