Mercedes Sprinter EDC16 dump
Results 1 to 11 of 11
    DK Veteran BALI7605's Avatar
    Gold Coast QLD AU
    167
    Default Mercedes Sprinter EDC16 dump
    Hello All,
    I have another big fight with a 2008 Sprinter 213 cdi, the ecu sticker is attached. I need an original dump. I have downloaded the map with MPPS and someone edited the DPF out and then i reloaded the map and the truck did turn over but not start. The ecu keeps the regulator open. So i loaded the original back in but it was the same no start regulator open. if you have the original map PLEASE send it to me or if you have a working DPF off on this please share with me. From this point BDM only on this unit.
    Thank you
    bali
    Aug 2011
    ukraine
    39
    Software nomber? And attach you readed file
    Gold Coast QLD AU
    167
    Default Corrupt file
    This was what i read out in the first place BUT when i load this file engine wont even crank.
    I thought the software version is the big number on the sticker which is A646 150 61 72 SW24.07
    Thank you
    Aug 2011
    ukraine
    39
    Test this full BDM
  5. The Following User Says Thank You to arthoor0 For This Useful Post:
    BALI7605 (13th November, 2014)
    Gold Coast QLD AU
    167
    Thank you i will let you know soon
    Gold Coast QLD AU
    167
    Arthoor,
    Your file is only 691kb the normal file is 2048kb, how did you read this? BDM comes up as wrong files size too.
    Nov 2013
    UK
    102
    immo is inside BDM flash ready. OBD read doesnt contain immo.
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    Aug 2011
    ukraine
    39
    Quote Originally Posted by BALI7605 View Post
    Arthoor,
    This file is full compressed bdm.You need exract with bdm prog.
  10. #9
    Aug 2011
    ukraine
    39
    This file for mpps
  11. #10
    Nov 2013
    UK
    102
    Thank you
    Your attached file is original.
  12. #11
    Dec 2015
    hi . is this file 100% original ?
