nobody?
if somebody has other eeprom dump for this car, it may helps...
Hi All,
I need immo off sulution for an old Ford Puma 97FB-12A650-HC LP2-110 MUFF EEC-V.
I have 2 keys (red and black), but I couldn't learn them, I think the ECU is damaged, don't give signal to the PATS.
Here is the original file from 77012 (25040):
Ford Puma LP2_110 97FB_12A650_HC MUFF ori 77012_25040.zip
even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
nobody?
znoki (16th November, 2014)
I don't have solution for this ECU.
Few days ago I had EEC-V:
http://www.digital-kaos.co.uk/forums...4/#post2415004
BUMP!
any idea?
Hi How did you solve? i have similar vehicle trying to code key with tango but doesn't recognize my dump and yours?
Hi, I can't solve it without any help. (sv2hqx sent me off topic pm, that's why I was disappointed)
But if you find something, please write it down here!
I will let you know are those keys you have 4d or 4c? Found these dumps added 4c to Ford Puma with tango but no start vehicle being brought in to me this morning will post results
Hi mates,
I have LP2-110 to try to do immo off. Can anyone help me please?
Thanks a lot
I also have the MUFF version of EEC-V on a 1998 Puma. Owner has only one key (black) and suddenly car doesn't start. Immo light goes solid ON when turning ignition ON. If the transponder is removed from key then Immo light flashes quickly.
I tried using Forscan but it says incorrect Incode with automatic calculation or manual calculation.
One DTC is set for PCM saying that sometime IGN was set ON when less than 2 keys programmed?!
Who has experience with these old cars? I think it only supports time key coding? Anyone confirms?
Hi mate,
I couldnīt do the immo off there Sorry
