    Jan 2012
    Default sprinter 3.0 v6 dpf
    please remove
    dpf from mercedes sprinter 3,0 edc16cp31
    I tried swiftec but mil still flashing
    Thanks for help
    Germany
    try and report,pass PM.
    disconnect connector from temperatur sensof and sensor diff.pressure
    Best regards Eddy
  3. The Following User Says Thank You to 16eddi67 For This Useful Post:
    wflseba (14th November, 2014)
    Ukraine, Kiev
    Try and report, pass in PM. Disconnect connector from temperature sensor and sensor diff.pressure.
  5. The Following User Says Thank You to nokius For This Useful Post:
  6. #4
    Jan 2012
    Both solution is the same and not work for me, mil light still flashing and no power,
    dtc p2089 exhaust back pressure sensor.
    Oct 2010
    Becouse exaust back pressure sensor must working, this sensor is near the turbo try to clean it sometimes it's full of soot and back pressure raising to much.
  8. The Following User Says Thank You to twincam For This Useful Post:
    wflseba (15th November, 2014)
  9. #6
    Jan 2012
    Thanks friends probelm sloved, dpf solutions working ok, and exaust back pressure sensor was broken.
