Results 1 to 7 of 7
Hybrid View
    Default new firmware needed
    can anyone please give me the link for firmware update for a f5 skybox thanks rodds
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    why do you need new firmware?
    Jun 2014
    my skybox has gone off, anyone else have this problem . cheers
    Nov 2014
    Quote Originally Posted by H0ltender View Post
    Well mine has developed a rebooting loop problem goes to L100 then reboots nothing comes up on screen..I need help on this please
    Apr 2010
    Quote Originally Posted by Punjabilad View Post
    Have you tried unplugging the Sat Feed and then rebooting box?
    Nov 2014
    Quote Originally Posted by intel View Post
    Ok so just unplug the sat feed and replug and retry?
    Apr 2013
    if it loads up no problem with the coax out then it may show that there is an issue with your coax shorting the box. Sometimes that is because the cowboys that installed your sly didnt cut your coax proper. You need to take off the F connecter to see if there is any lose copper wires touching the f connecter that can cause it to boot. I would check it in a mates house as well if it works fine there is an issue somewhere at your end causing the issue. A blown LNB or just something shorting it. Should be easy to fix.
