Results 1 to 5 of 5
    DK Veteran cleevesy's Avatar
    Mar 2010
    Default Ml 320 Start error no coms with aam
    Have a ML 320 2003 with start error and No Communication with AAM with Star , can talk to DAS and EAM has a Permanent Fault code B1367 Can Bus Fault in Communication AAm on Internal Can .. have fitted another secondhand hand AAM still no coms
    Have made new Transponder with Abritus and still have start error
    Anybody have a idea on why no communication with AAM , Can lines faulty??
    Or shall i renew Engine ECU?
    Any help much appreciated thanks
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    Quote Originally Posted by cleevesy View Post
    Check circuit integrity of com-lines FIRST. then power and ground to the affected modules.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  3. The Following User Says Thank You to teuton For This Useful Post:
    cleevesy (17th November, 2014)
    Mar 2010
    I have checked communication lines and power supplies and all is ok, do you think the Das/EAM is faulty and this stops communicationm to the AAM?
    Nov 2009
    Mexico
    Yes ,I think so if all your connections are fine. This isapattern failure on this model, br.
  6. #5
    Mar 2010
    Update turns out it was a faulty EAM module giving the start Error , cars all running
