Results 1 to 5 of 5
    Sep 2012
    Tunisia
    Default w203 ezs dump check
    hi all
    i receive a faulty ezs 203 545 01 08 with two CPU first is 2J74Y for km and vin data the second is 4j74y for keys data
    the problem was that the ezs work only when warm i change two CPU with new one program it with r270 and test with ezs key checker light gos on and off normally
    when i test it on table with the esl nothing happened. can someone check my dumps and correct them if possible?
    Abritus72 original, omega programmer, ak500+, op-com, bosch kts, autocom cdp+ clone, fgtechv clone,mpps v13 clone, super vag k clone, xprog v5.50 clone, upa, bdm100, clip, diagbox, sbb, t300, gambit,carprog original
  2. The Following User Says Thank You to Aniskey2 For This Useful Post:
    mcday (15th January, 2016)
  3. #2
    Sep 2012
    Tunisia
    no one can check it
    autodigitec's Avatar
    Aug 2011
    PT
    When you warmed the mcu, did the key turn to ignition?
    Ill check the dumps once I arrive at office.
    Did you program flash in the new mcus or did they come from another ezs and same positions?
    Enviado do meu ZP998 atrav?s de Tapatalk
    Working on something to release next month for free for all dk users :>
  5. The Following User Says Thank You to autodigitec For This Useful Post:
    Aniskey2 (21st November, 2014)
  6. #4
    Sep 2012
    Tunisia
    i don't check it if it turn or not but when it come i check with ezs key cheker and light no illuminate and when i warm the cpu light go on normally
    and go off when cpu is cold
    after replace cpu 2j74y from other used ezs and program eeprom with original dump with r270
    then try it on table with cables nothing happened
    i try to change 4j74y and same thing
    thanks for help
    Aug 2011
    PT
    Well thats weird, did you check the used ezs before opening it?
    I had a case like this a few days ago. When used ezs arrived i tested first, then cloned both eeproms and made keys and its good to go.
  8. The Following User Says Thank You to autodigitec For This Useful Post:
    Aniskey2 (24th November, 2014)
