does anyone knows how to connect L line to galletto 1260 ?
Hi , if someone knows where I can find
MPPS software
first, the vag com interfaces are based on ft232bm, which doesn't have attached an external eeprom, so you have to modify it.
one vag com interface si 12$ and galletto is 25$ . so there's not big difference.
but the problem with the galletto is that it don't work as the vag com interface for diagnostic, i think because it doesn't have the l-line connected.
Hi guys,
I get galletto error when I try to read ecu data from my car (Vw passat 1.9). I just bought a galletto 1260 clone.
Can someone please help me?
Thanks.
maybe you haven't selected the wright driver
nope, you installed ok, maybe your windows directory path is too long or has strange chars and the program can't write the file. try copying the software closer to the root of one drive and run from there.
hello everybody need help my ft232bm is writed with one ept and it give to me "this clone is not permited" how to fix?
2 pics with different Galletto.
one is compatible with the Dacia Logan and one is not
can you tell us where did you bought them?
the only problem with logan are the petrol ones, which have Siemens ECU , and they need L-line for wakeup. Not all Gallettos have L-line connected.
The same trouble.
Recently I've received Galletto 1260, based on FT232RL and with L-Line connected. But it can't connect with Logan, giving me "ERROR SEND WAKE"...
Photos attached (I also tried to connect K and L directly, as shown on the pic, but no result).
