Results 1 to 3 of 3
    Nov 2014
    Default (Help) Using TPLINK ETHERNET POSSIBLE?
    have a openbox f5s, my router is way away from where tv is however dont wanna use wifi adapter cause of weak signal, have a tplink power kit, however plugged it in and doesnt get ethernet, is there anything i need to setup in settings or something ? thanks
    Oct 2011
    hi you may need to change network settings from wireless to wired(cable) connection like some receivers. Make sure also that ethernet cable is properly connected.
    Oct 2008
    After plugging adapters into router and box, press reset buttons on adapters.All light should be green now on adapter
