Am I inpolite if I post my question here?
I'm looking for the long code for BOSCH ABS module VW Polo 2010.
VIN: WVWZZZ6RZAY203922
SW: 6R0907379AE + HW: 6R0907379AC
Could you help me out?
With kind regards,
Timo
With kind regards,
Timo
Hi.
Can anybody help to generate long code for Octavia II(1Z) 1.6 FSI
VIN: TMBHB61Z582198734
1K0907379AN
ESP MK60EC1 H45 0107
Can someone send me the program in email :xxxxxxxxxxxx
Thank you
Hi.
Can anybody help to generate long code for VW JETTA (16) 1.4 FSI
VIN: 3VWD67AJ5GM358022
1K0907379CC
ESP MK60EC1 H46 0175
bgp
113b401c092b0002881202e7901d0001e800
Hello I need a long code ESP ABS for an Octavia BJ 2008 1.8L TSI with the chassis number tmbgk61z698010684 can help me urgently
someone can help me with long coding code for seat ibiza 2010 ???
VIN: VSSZZZ6JZAR059732
vag number:6R0907379AD
LHD
FWD
CGP i think engine code
Hello, i no this is a bit of an old thread. but i am in need of help, i have pulled a cluster out and its killed the ABS long coding, i can supply the auto scan from VCDS if needed but any help will be much appreacited,
Seat Leon 2.0TDI FR 170BHP 2009
VIN:VSSZZZ1PZ9R510518
ABS Part Number :1K0 907 379 AM H45
Manuel
disc size is 312mm front and rears are 272mm
anything else you need to no please let me no as i am in a right muddle !
thanks in advanced
shane
Edit,
163B6012092300FA681006E5902100823400
is the code for anyone with similar issues if this helps
Can someone please help with ABS Controller Module MK60ec1 code
Car is Golf Aug 2008 2.0FSI with ABS/ESL
VIN: WVWZZZ1KZ9U004161
Module Number: 1K0 907 379 AD
Car has 288mm front discs and 255mm rears (What I have been told)
Car has standard 16" rims
Old unit died, no communication through scanner.
Have replaced unit with identical unit but now ABS/ESL/Brake dash lights blinking and constant beeping
Needs coding
The beeping is constant so annoying to drive anywhere.
Hello there,
i need to generate long code for my VW Polo 6r 1.4 (2011)
VIN:WVWZZZ6RZBY335343
CGGB MM4HV
6R0907379AB
Thank you in advance!
VW JETTA 2008 ABS LONG CODE NEED
VIN WVWK081K29A240178
P.N.1K0 907 379 AE
JETTA 1.9AT RHD
Sent from my SM-J730GM using Tapatalk
HMMM i need to check
