Page 3 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 136
  1. #31
    Mar 2020
    Hallo
    I have a VW Tiguan.
    Vin: WVGZZZ5NZ9W079309
    ABS Module Number: 5N0 614 517 M
    Lost coding from ABS module
    Can you help me???
    Thank you, Thanos...
  2. #32
    Mar 2020
    Hi Will this work for ESP 8.2 and not 8.2i
  3. #33
    Apr 2016
    Hi , I need ABS Long Coding For Skoda Octavia, tahnk you in advance .
    ABS/ESP MK60EC1
    1K0 907 379 AN
    TMBDS21Z782239291
  4. #34
    dgmcan's Avatar
    CANARY ISLANDS
    Hi!
    I need help with long coding ABS 8.2
    SW 6R0 907 379 S HW 6R0 907 379 AB
    VIN: TMBEM25J5E3088816
    Engine: 1.2TSI CBZA SIMOS10.22
    LHD
    I fix what others break.
  5. #35
    Jul 2020
    Default help
    Quote Originally Posted by rob h View Post
    Attachment 288243 Here is a file that has download links to the Esp Abs prog
    hi how can I download this???
  6. #36
    May 2017
    Helloo
    A need long coding ABS/ESP
    Audi 1
    A3 8P 1.9TDI ABS/ESP MK60EC 1K0 907 379 C
    VIN WAUZZZ8P49A051461
    Thanks for help
  7. #37
    Nov 2020
    Hello! I need your help in order to code my new ABS/ESP module. I replaced it with the new one. I can not code the new one. Please , help me. I'll give you all the information
    new ABS module is 1K0907379AH / ESP version:ESP MK60EC1
    my car's VIN is WVWZZZ1KZAP169073
    VW GOLF 6 1.4 122hp/90kw Thank you very much for your support and answer!
  8. #38
    Aug 2019
    1k0 907 379 be esp mk60ec1 h31 0108 ffor golf 6 R
    wvwzzz1kzbw237320 need abs codig
  9. #39
    Dec 2020
    Manaus
    Olá! Preciso de sua ajuda para codificar meu novo módulo ABS / ESP. (1C0 907 379 C)
    1. novo módulo ESP versão: ESP MK60
    2. O VIN do meu carro é: 9BWHE21J344022358
    3.GOLF GTI MK4 2004
    4. LHD
    5. 1.8 Motor tURBO, TIPTRONIC
    6.FWD
    7. nenhum sistema start / stop instalado
    8. SENSORES NAS 4 RODAS
    9. Meu carro tem botão liga / desliga ASR / ESP
    Muito obrigado pelo seu apoio e resposta!
  10. #40
    Feb 2018
    norbneto Try code ABS: 0001025 or 0004097
  11. #41
    Dec 2020
    Manaus
    Tentei esses dois mas sem sucesso..
    Apresenta o erro:01044 incorrectily coded.
  12. #42
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    hello
    i need help to adaptation or codind ABS module for a passat 2006 motor code BMM.
    i don t know what is the problem with this car ,only thing coustumer tell me he try to change the brake module ,then he have the error ABS,ESP ,STERING .
    So i try to coding ABS module with vcsd ,i loget with 40168 , everithig ok till i read { measuring bloks 08} group 04 field 1 i have 0 and no move of 0 ,i move the stering buo still show me 0 .
    change the stering module {same code } but no work ,i have same 0 .
    is there another metode to code this module .
    here i put the log file from vcds .
    thank all for your time and help '
    best regrads
  13. #43
    Dec 2020
    Hi guys i am writting from va usa i was recomended by a friend . I have spent 1 month looking for help to find the coding for my 09 gti abs with no luck .
  14. #44
    Jan 2021
    Hello! I need your help to code my original ABS/ESP module. I have conected another instrument cluster and now the codding is zero. Please, help me...
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 73430 790 00999
    VCID: 7AFACA74F5DF5896C4-802E
    VIN: TMBGT61Z9A2085173
    2010 Skoda Octavia
    LHD
    1.6 TDI engine
    DSG DQ250
    FWD
    Only ASR/ESP on/off button
    Thank you a lot.
  15. #45
    Jan 2021
    THANK YOU MY FRINDS
