Page 4 of 9 FirstFirst 123456789 LastLast
Results 46 to 60 of 134
  1. #46
    captain crackers's Avatar
    england
    Hi could anyone help with the ABS coding for a 2015 Seat Ibiza vin VSSZZZ6JZFRO95050.
    ABS 6R0 907 379 BH
    COMPONENT ESP9.0i front H03 0001
    INSTRUMENT 6J0 920 907 K
    Thanks in advance Arthur.
  2. #47
    england
    Problem solved.
  3. #48
    igendek's Avatar
    Hi, could you help me with coding CADDY 2.0 tdi cr, 2014, automat?
    I ve got: 0000000000000000000000000000000000000000
    VIN: WV1ZZZ2KZEX098700
    1K0 907 379 BM
    ESP MK60EC1
  4. #49
    Aug 2018
    Hi could i please get thenlong coding for this A3, i tried everything and connot get it
    audi a3 1.9tdi bls engine code
    vin wauzzz8p39a026180
    brakes
    1kd 1zf
    advance id of abs
    Thursday,18,February,2021,14:59:59:39744
    VCDS Version: Release 17.1.3
    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 AD
    Component and/or Version: ESP MK60EC1 H35 0104
    Software Coding: 000000000000000000000000000000000000
    Work Shop Code: WSC 06314
    VCID: 74E00792D7206FE1FD-8020
    Advanced Identification
    Identification: TT1-000
    Revision: 00H35001
    Date: 13.07.08
    Manufacturer number: 0101
    Test stand number: 07B3
    Flash Status
    Programming Attempts(application): 0
    Successful Attempts(application): 0
    Programming Status: 00000000
    Flash Date: 2008.08.04
    Flash Tool Code: 00000 000 00000
    Misc.
    Hardware number: 1K0 907 379 AD
    Workshop System Name: -----
    VCDS Info:
    Labels: 1K0-907-379-60EC1F.clb
    fault codes
    Thursday,18,February,2021,15:06:36:39744
    VCDS Version: Release 17.1.3 Running on Windows 8.1 x64
    www.Ross-Tech.com
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 AD HW: 1K0 907 379 AD
    Work Shop Code: WSC 06314 000 00000
    5 Faults Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:23:59
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12288
    Count: 320
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:23:59
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 270
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 291
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    thank you
  5. #50
    Dec 2020
    Hello. I urgently need abs encoding. Skoda octavia 2016year.Mk100.Vin: TMBJC7NE6G0201825
  6. #51
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Hi can anyone calculate long coding for this 2014 caddy with esp mk60ec1 1K0907379BM VIN WV1ZZZ2KZFX039459 1.6TDI FWD RHD?
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
  7. #52
    Sep 2020
    GOOD MORNING MEMBERS I SEARCH FOR LONG CODING ABS WITH THIS TECHENICAL INFORMATION PART NUMBER :3Q0 907 379 P AND VIN:VSSZZZ5FZFR159126
    THANK YOU FOR HER HELPS
  8. #53
    Jul 2021
    part number :
    1K0-907-379-BG
    VIN WVWDM7AJ2BW226577
    THANK YOU FOR HELP
  9. #54
    Feb 2018
    ВСЕМ ПРИВЕТ! hI Gays!
    прошу помочь. ищу длинную кодировку для Октавия 3
    TMBAN2NE1FD006462
    breake Conti MK100ESP
    detals 5Q0907379K
    version 033001
    progs 0371
    apparate H31
    serial nambers 62514000002156
    ____________________________________
    please help. looking for long encoding for Octavia 3
    TMBAN2NE1FD006462
    detals 5Q0907379K
    version 033001
    progs 0371
    apparate H31
  10. #55
    Oct 2017
    Hello members, i need help with ABS long coding MK7 1.4TSI 2014 Manual, below is the autoscan using VCDS.
    Saturday,13,November,2021,18:25:51:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.9.0.2 (x64)
    Data version: 20210903 DS330.0
    www.Ross-Tech.com
    VIN: WVWZZZAUZEP041304 License Plate: UBK_070U
    Mileage: 99280km-61689mi Repair Order: MK7
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEP041304 Mileage: 99280km-61689miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 016 DE HW: 04E 907 309 A
    Component: 1.4l R4 TSI H08 5672
    Revision: WAH08--- CVN: 0CE7C3B0
    Coding: 01190012242415082000
    Shop #: WSC 00028 028 00074
    ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
    ROD: EV_ECM14TFS01104E906016DE_VW37.rod
    VCID: 68DF0DA79373D2C9E9-803C
    VINID: 9E69EAAAA465A958001010C010E6D8BBA9
    2 Faults Found:
    17158 - Databus
    U1123 00 [039] - Received Error Message
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 01:00:19
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 94 °C
    Intake air temperature: 54 °C
    Ambient air pressure: 870 mbar
    Voltage terminal 30: 12.510 V
    Unlearning counter according OBD: 40
    Mass flow through throttle valve: 0.0 kg/h
    Mean injection time: 0.000 ms
    Engine operating condition: Idle
    Engine operating condition-Test_Program_Channel 87: 5
    4716 - No Communications with Parking Brake Control Module
    U0128 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 01:03:59
    Coolant temperature: 92 °C
    Voltage terminal 30: 12.392 V
    CAN status - engine control module-Bits 0-7: 0
    selected gear-Bits 0-7: 0
    Readiness: 1110 0001
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
    Component: ESC H31 0472
    Revision: 00000000 Serial number: 626730000006BD
    Coding: 00000000000000000000000000000000000000000000000000 0000000000
    Shop #: WSC 131071 1023 2097151
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
    ROD: EV_Brake1UDSContiMK100IPB_033.rod
    VCID: 071D2E1BBE2D3DB100-8052
    16 Faults Found:
    0072 - Rear Left Wheel Speed Sensor
    C101C 01 [137] - Electrical Failure
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0088 - Rear Right Wheel Speed Sensor
    C101D 01 [137] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0195 - Control module not coded
    U1013 00 [137] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0212 - Longitudinal Acceleration Sensor
    C1017 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0270 - Lateral Acceleration Sensor
    C1079 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0279 - Brake Pressure Sensor 1
    C107A 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0295 - Steering angle sensor
    B1168 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    0398 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:23:30
    4161 - Coding invalid
    U10DA 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:33:44
    8278 - Control Module Incorrectly Coded
    U1014 00 [137] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    8290 - Coding Not Possible
    U10BC 00 [137] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:23:34
    8306 - Databus
    U1122 00 [137] - Implausible Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:23:34
    8308 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    32848 - Control Module for Electric Parking Brake
    C10E2 F1 [137] - Switches/Motors Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:17:34
    32900 - Left Parking Brake Motor Voltage Supply
    C100D 13 [137] - Electrical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 03:16:30
    32951 - Control Module for Electronic Parking Brake
    C10E2 54 [137] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 139
    Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
    Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
    Component: AC Manuell H01 0705
    Revision: 00001K06
    Coding: 00120004200100001000000000000000
    Shop #: WSC 00028 028 00023
    ASAM Dataset: EV_ACManueBHBVW37X 003019
    ROD: EV_ACManueBHBVW37X_003.rod
    VCID: 356194D394417F21A2-8060
    Fresh air blower control module (front):
    A/C pressure/coolant temperature sensor:
    1 Fault Found:
    1048838 - Functional Limitation due to Energy Management
    B10CD 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 04:31:22
    Voltage terminal 30: 11.3 V
    CAN input signal(s) status-Transport mode: On
    CAN input signal(s) status-Static current measuring mode: OFF
    CAN input signal(s) status-Windshield wiper: OFF
    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
    CAN input signal(s) status-Wipe wash: OFF
    CAN input signal(s) status-Rear window heater actual value: OFF
    CAN input signal(s) status-Back-up lamp: OFF
    CAN input signal(s) status-Actual value of windshield heater: OFF
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
    Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
    Component: BCM MQBAB B H14 0112
    Serial number: 00011326100272
    Coding: 03000842C24100534BE4400000040308100000000000000000 0000000000
    ASAM Dataset: EV_BCMCONTI 011001
    ROD: EV_BCMBOSCH_011.rod
    VCID: 479DEE1BFEADFDB1C0-8012
    Wiper motor control module:
    Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 130825 042 0551
    Serial number: 130907184020
    Coding: 0E4DDD
    1 Fault Found:
    11274 - Bulb for Center Brake Light
    B12C6 15 [009] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:57:43
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
    Component: AirbagVW20 014 0385
    Serial number: 003F6R01202D
    Coding: 98CCC000000000005C00000000C800000065
    Shop #: WSC 00028 028 00055
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 4189F003D089C3810E-8014
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 001 302 16
    Component: SideSensor_Df 001 0887
    Serial number: 35767000000B4024291I
    Coding: 2D2D2D
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: ----------- HW: 480 001 109 13
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000A3410AD0R
    Coding: 2D2D2D
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 3 - Part No SW: ----------- HW: 480 402 609 13
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502B711D1520817-
    Coding: 2D2D2D
    Passenger side rear thorax airbag crash sensor:
    Subsystem 4 - Part No SW: ----------- HW: 480 402 709 13
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502B311FBEB5118J
    Coding: 2D2D2D
    Crash sensor for front airbag: driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 402 709 13
    Component: FrontSensor_D 001 6149
    Serial number: 35565029F1171FE180CO
    Coding: 2D2D2D
    6 Faults Found:
    9440027 - Driver's side; side-airbag igniter
    B100B 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:26
    9438747 - Igniter for Seat Belt Tensioner; Driver's Side
    B1006 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:26
    9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
    B1007 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:26
    9438491 - Igniter for Driver head airbag
    B1005 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:26
    9438235 - Igniter for Front passenger's Head Curtain Airbag
    B1004 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:26
    9682162 - Multiple collision brake
    B13BC F2 [137] - No function
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 02:31:42
    Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
    Part No SW: 5Q0 953 507 AA HW: 5Q0 953 549
    Component: Lenks. Modul 007 0070
    Revision: -------- Serial number: 23091304221078
    Coding: 0400
    ASAM Dataset: EV_SMLSKLOMQB 009001
    ROD: EV_SMLSKLOMQB_009_VW37.rod
    VCID: 75E154D3D4C13F2162-8020
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
    No fault code found.
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 5G0 920 861 HW: 5G0 920 861
    Component: KOMBI 252 2210
    Coding: 27A419002380000800082800040000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008031
    ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
    VCID: 66C3039F9967C4B9DB-8032
    2 Faults Found:
    16776967 - Databus
    U1121 00 [009] - Missing Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 01:03:59
    16776973 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 01:04:03
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 L
    Component: GW MQB Mid 211 2147
    Revision: -------- Serial number: 19091310801940
    Coding: 030100342B086400EF000048080F0001000100000000000000 0000000000
    GVL: 01503C0000000000400C000000004800000000000000000000 00000000000000
    ASAM Dataset: EV_GatewConti 009011
    ROD: EV_GatewConti_009.rod
    VCID: 3A7B87EFBD5F90594F-806E
    Generator:
    Multifunction steering wheel control module:
    Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H15 0038
    Serial number: 27130001472820093375
    Coding: 28FFFF
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
    Component: J367-BDMHella H03 8042
    Serial number: 5876981403
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
    Component: TSG FS 020 0041
    Serial number: 080216EB801499
    Coding: 003003208001048000001000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    Rear Driver Side Door Control Module:
    Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
    Component: Fond FHSG DRV 007 0002
    Serial number: 00000000000002833245
    Coding: 0D0000
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
    Component: EPS_MQB_ZFLS 123 1043
    Coding: 0103
    ASAM Dataset: EV_SteerAssisMQB 010031
    ROD: EV_SteerAssisMQB_010.rod
    3 Faults Found:
    20228 - Databus
    U1123 00 [008] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 179
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:58:52
    Motor status: 01
    System status: Driving mode
    Supply voltage: 13.50 V
    Temperature: 45.0 °C
    KFC: 4F
    KFA: 00 04
    Freeze frame conditions: 21
    uAdSensI_U1V2Filtered_gdu16: 1.20 V
    uAdSensI_U5VFiltered_xdu16: 0.00000 V
    uioUdNotFilt_xdu16: 13.64 V
    uAdSensI_SwitchedKl30_xdu16: 13.63 V
    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
    19716 - Databus
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 179
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:58:52
    Motor status: 01
    KFC: 4D
    KFA: 00 04
    uioUdNotFilt_xdu16: 13.58 V
    uAdSensI_SwitchedKl30_xdu16: 13.59 V
    19204 - Databus
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 179
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 01:03:59
    Motor status: 00
    System status: Waiting for start request
    Supply voltage: 12.25 V
    KFC: 4B
    KFA: 00 04
    uioUdNotFilt_xdu16: 12.30 V
    uAdSensI_SwitchedKl30_xdu16: 12.31 V
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 392 HW: 5Q4 959 392
    Component: TSG BFS 007 0006
    Serial number: 0000075401522
    Coding: 003003208001020000800000
    ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    VCID: 7F0DB6FBE6FD757138-802A
    Rear Passenger Door Control Module:
    Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
    Component: Fond FHSG PSG 007 0002
    Serial number: 00000000000002774149
    Coding: 050000
    Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
    Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
    Component: MU-S--ER 040 0421
    Serial number: V1C02909131378
    Coding: 02730000FF00000011510001000900001F0100860100010001
    ASAM Dataset: EV_MUStd4CPASE 002039
    ROD: EV_MUStd4CPASE_VW37.rod
    VCID: 275D4E9B5EED1DB120-8072
    Display and control head 1 for information electronics:
    Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
    Component: ABT_Std_Radio H50 0022
    Serial number: VWZ8Z9NJ701RT2
    4 Faults Found:
    0004 - Antenna 2 for radio
    B111A 11 [009] - Short to Ground
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:45
    Voltage terminal 30: 12.3 V
    Status of antenna 2 for radio-Antenna current: 0 mA
    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Short circuit
    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
    0005 - Antenna Amplifier 1 for Radio
    B126D 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 00:53:45
    Status of antenna 1 for radio-Antenna current: 0 mA
    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
    7175 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 02:31:43
    Voltage terminal 30: 12.0 V
    BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 99280 km
    Date: 2021.08.26
    Time: 02:31:43
    End-------------------------(Elapsed Time: 03:10)--------------------------
  11. #56
    Nov 2021
    Quote Originally Posted by rob h View Post
    Attachment 288243 Here is a file that has download links to the Esp Abs prog
    Thanks for the links !!
  12. #57
    Dec 2021
    If anyone could help I'd be so grateful.
    I swappd out the intrument panel on my daughters 2011 seat ibiza which I thought was broken. Turns out it wasn't and have lost the abs coding.
    Its a 2011 1.2tdi
    VSSZZZ6JZCR060425
    6R0 907 379 AD
    Compomemt ABS8.3 front H03 0001
    FWD
    Thanks so much in advance!
  13. #58
    Jan 2022
    Con iscancar mm07 se hace un snirfeo se hace simulación del modulo posteriormente se calcula con launch thinkar y listo ✅ probado en muchos coches con éxito
  14. #59
    Apr 2021
    Quote Originally Posted by Austin60 View Post
    Its a 2011 1.2tdi
    VSSZZZ6JZCR060425
    6R0 907 379 AD
    FWD
    100200DB007300B2082900E400D600000000
  15. #60
    Jan 2016
    Angry Polo 6R coding
    Hi from Spain,
    I need ESP coding for my new car please, I bought it and has it disconnected
    No codings stored in ABS
    Polo Hatch 6R, Manual 1.6TDI CAY, LHD
    Vin: WVWZZZ6RZAY084297
    Abs Bosch 6R0 907 379 S
    Front disk 256mm
    Rear drums 200mm
    Many thanks in advance.
    Best regards.
