Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 136
  1. #121
    spiridonas's Avatar
    Hi please i need long coding from Audi A3 2009
    VIN : WAUZZZ8P59A010448
    1K0907379AD Mk60EC1
    Many thanks in advance
  2. #122
    Feb 2024
    Default Abs
    Hello, can someone help about coding abs ?
  3. #123
    Feb 2024
    Hello i need help about coding .
  4. #124
    Feb 2017
    Default Buenas necesito ayuda
    Hola buenas tardes necesito de nuevo ayuda en muchas ocasiones me ayudaste
    Necesito long códig ABS SEAT LEON TDI 1.9
  5. #125
    Feb 2017
    Buenas este el VIN VSSZZZ1P29R004788
  6. #126
    Feb 2024
    Could someone help me calculate the abs systems Long coding line mine was lost. Car is Seat Leon FR 2015.
    Vin number : VSSZZZ5FZFR074283
  7. #127
    Jan 2009
    Need long coding for Golf MK6
    Control Module Part Number: 1K0 907 379 CD HW: 1K0 907 379 AD
    Component and/or Version: ESP MK60EC1 H35 0120
    Tnx
  8. #128
    Feb 2020
    thanks for the program sir
  9. #129
    Mar 2016
    Hi can you help me with long coding abs module?
    Seat Ibiza 6j
    SW 6r0907379H hw 6r0907379H
    ESP8.2i front H04 0005
    Kod serwisu Wsc 04941 000 00000
    VCID: 4385FA0BC695D157C4-8016
    Vin VSSZZZ6JZ9R035811
  10. #130
    Slovakia/Bratislava
    hallo. can somebody help me with coding. i replace abs with faut for new one with hw code 46 but coding is longer.
    i have log before and after.
    can somebody help me with this i put log here
    Thursday,16,May,2024,17:01:02:16365
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
    Data version: 20231027 DS351.0
    www.Ross-Tech.com
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9W481038 Mileage: 208950km-129835miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
    Part No SW: 03C 906 027 BS HW: 03C 906 027 F
    Component: MED17.5.5 G 0888
    Revision: L1H08--- Serial number:
    Coding: 0000072
    Shop #: WSC 08778 995 175582
    VCID: 73B3DFD177B6D642221-8026
    VINID: 9E69EAAAA05BA899C420100320D36B1C40
    No fault code found.
    Readiness: 1110 0101
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Coding: 143B600D092A00FB280B06E7902100403400
    Shop #: WSC 54918 002 1048576
    VCID: 76B5E6C568C4C36A05F-8022
    1 Fault Found:
    16352 - Control Module - Electrical Error
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 208950 km
    Time Indication: 0
    Date: 2018.10.07
    Time: 07:38:50
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 4608
    Count: 96
    Count: 51983
    Count: 1806
    Count: 0
    Count: 0
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
    Component: Climatronic 130 0305
    Revision: 00002001
    Coding: 0000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 73B3DFD17B36D642221-8026
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 HW: 1K0 937 086
    Component: BCM PQ35 M 020 0358
    Revision: 00020000
    Coding: 40180A3A98251AC040080080140081E445510088536D896064 8000000000
    Shop #: WSC 01357 011 00200
    VCID: 6D87C9A91D9200B2F45-8038
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 05010 21 0501
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 160109 05 54 0402
    Coding: 0330AD
    1 Fault Found:
    00907 - Intervention load Management
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 80
    Mileage: 208950 km
    Time Indication: 0
    Date: 2018.10.07
    Time: 10:22:43
    Freeze Frame:
    Term 15 On
    Voltage: 11.75 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
    Part No SW: 5K0 919 475 HW: 5K0 919 475
    Component: PARKHILFE 8K H07 0002
    Revision: -------- Serial number: 60640900904414
    Coding: 100001
    VCID: 73B3DFD17BB6D642221-8026
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5K0 959 655 HW: 5K0 959 655
    Component: AirbagVW10 033 0604
    Serial number: 003C2D08DD8T Dataset Number: v00300555K0 0001
    Coding: 00003135
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 77ABEBC16F4EBA621E9-8022
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V U01 ----
    Serial number: 5B376142ZZZZZZZZZZZZ
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V U01 ----
    Serial number: 70136642ZZZZZZZZZZZZ
    Rear Side Airbag Crash Sensor (on driver's side):
    Component: S.Sens.Fahr.H --- ----
    Serial number: 124B1952ZZZZZZZZZZZZ
    Passenger side rear thorax airbag crash sensor:
    Component: S.Sens.Beif.H --- ----
    Serial number: 08111B10ZZZZZZZZZZZZ
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 055 0111
    Coding: 0000532
    VCID: 78A9E8FD6ED0B51A173-802C
    Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAP H4˙ 0021
    Coding: 00000226
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K0 920 870 B HW: 5K0 920 870 B
    Component: KOMBI H21 0029
    Serial number: 00000000000000
    Coding: 170B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 2C0104ADE688C9BAA3B-8078
    Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533 Gateway H07 0071
    Revision: H07 01 Serial number: 070109F1000152
    Coding: E9A07F06400212000002
    VCID: 372B2BC1234E7A62DE9-8062
    Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
    Component: IMMO H21 0029
    Serial number:
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0084
    Revision: A1001003 Serial number: 7667335739
    Coding: 010000
    VCID: 2615F685F8E4F3EA75F-8072
    Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
    Component: RNS-MID H04 2660
    Revision: AB001001 Serial number: VWZ6Z7J4015044
    Coding: 040004000400008200
    VCID: 2E050EA5D014BBAA8DF-807A
    2 Faults Found:
    00821 - Antenna 2 for Radio (R93)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 11
    Reset counter: 40
    Mileage: 208944 km
    Time Indication: 0
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 208944 km
    Time Indication: 0
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1K0 959 701 AG HW: 1K0 959 701 AG
    Component: Tuer-SG 008 2033
    Coding: 0004278
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 69 2501
    Revision: 00H15000
    Shop #: WSC 01324 785 00200
    VCID: 2C0104ADEA08C9BAA3B-8078
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
    Coding: 0004534
    VCID: 74B1DCCD72B8D17A3BB-8020
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 11
    Reset counter: 40
    Mileage: 208944 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 208944 km
    Time Indication: 0
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
    Component: Tuer-SG 007 2009
    Coding: 0000144
    Shop #: WSC 01357 011 1012552
    VCID: 7AADF2F550DCA70A617-802E
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
    Coding: 0000144
    VCID: 7BA3F7F15FE69E027A1-802E
    End----------(Elapsed Time: 01:00, VBatt start/end: 14.5V/14.5V)-----------
    s
    after
    Sunday,19,May,2024,18:43:49:16365
    VCDS Version: Release 23.11.0
    Control Module Part Number: 1K0 907 379 BM
    Component and/or Version: ESP MK60EC1 H46 0164
    Software Coding: 0000000000000000000000000000000000000000
    Work Shop Code: WSC 35110
    VCID: 7EA5FEE540F48B2A5DF-802A
    Advanced Identification
    Identification: TT1-07C
    Revision: 00H46001
    Date: 19.05.14
    Manufacturer number: 0104
    Test stand number: 09E1
    Flash Status
    Programming Attempts(application): 0
    Successful Attempts(application): 0
    Programming Status: 00000000
    Misc.
    Hardware number: 1K0907379BM
    VCDS Info:
    Labels: 1K0-907-379-60EC1F.clb
    thanks for any help
  11. #131
    May 2024
    Can you please help me
    WVWZZZ1KZ8M033917
  12. #132
    May 2024
    hope anyone can help. I have a friend with a Seat Ibiza which has a broken ABS Unit.
    Unfortunately he has chance the Unit before make a SW backup from the old Unit.
    Now he needs the long Code for the ABS.
    VIN: VSSZZZ6JZAR010596
    ABS Unit HW 6R0 907 379AB /SW 6R0 907 379AB ABS Front 8.2 H03 0001
    Seat Ibiza 1.4 TDI BMS Engine
    256mm Brake front / Brake Trums rear
    LHD 3 door
    I have tried the Calculator but the BMS Engine is not in the List, so the generated Code are wrong.
    Hope someone can help me please and has the right Long Code
  13. #133
    Jun 2024
    Hello! I need your help to code a replacement ABS/ESP module. Since my old one was broken (1K0 907 379 BE), I replaced it with another used one. In the program, it says that the module is not programmed and shows only zeros. I'm asking for help because I don't know how to proceed.
    1. new ABS module is 1K0 907 379 BE / ESP MK60EC1 H31 0108
    2. my car is Seat Leon 2011 VIN is VSSZZZ1PZBR074576
    3. LHD
    4. 1.4 TSI engine, manual gear
    5. FWD
    6. no start/stop system installed
    7.no TPMS sensors in wheels / with button set tire pressure
    8 .with ASR/ESP on/off button
    9. Brakes 280/253
    Thank you very much for your support and answer
  14. #134
    Oct 2020
    Hi ..please help i lost my long coding VW golf mk6 2012
    HW:1K0907379BJ
    VIN: WVWZZZ1KZCW219356
    1.4 tsi standard
    Auto transmission
    RHD
  15. #135
    Jun 2022
    Hello
    Have polo with bosch 8.2i .
    Car is japan import.
    Customer fit UK clocks and abs coding was set to 00000000.....
    When came to car Autel couldnt connect to abs .
    After that tried odis online it tried but couldnt do it.
    Now autel can comunicate with car but not accepting code from Esp Calculator
    Car vin number WVWZZZ6RZAU022722
    ABS part number 6R0907379R
    engine code CGGB
    Abs Coding by calculator 210228C2416F00B4842C14E482D300400700
    my change is rhd steering and tpms and hill assist 210228C2416F00B4842C14E482D300800300
    None of codes accepted.
    Can someone help with this one?
    My option is try to reflash abs module as looks like issue is there...
