Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 129
  1. #61
    Jan 2022
    solved please remove
  2. #62
    Jan 2016
    Polo 6R coding
    Hi from Spain,
    I need ESP coding for my new car please, I bought it and has it disconnected
    No codings stored in ABS
    Polo Hatch 6R, Manual 1.6TDI CAY, LHD
    Vin: WVWZZZ6RZAY084297
    Abs Bosch 6R0 907 379 S
    Front disk 256mm
    Rear drums 200mm
    Many thanks in advance.
    Best regards.
    Anybody?
    Many thanks
    Best regards
  3. #63
    Apr 2021
    Check your PM Box. Solution is in there.
  4. #64
    Jul 2016
    Buenos Aires, Argentina
    Quote Originally Posted by r4nd0mize View Post
    Hi, i need solution for My Audi A3 2008 8p. Thanks
    Enviado desde mi moto g(60)s mediante Tapatalk
  5. #65
    Apr 2021
    You need to leave information about whether left hand drive or right hand drive and if you have tpms. That applies for everyone, otherwise people cannot help here. And in your case (as you have been posting in several threads) I couldnt see you left that information somewhere.
  6. #66
    Jun 2022
    Hola, para un vw golf 7 de 2016 me podrían poner la long coding del modulo 03 ABS, si es así os doy toda la documentación necesaria, gracias
  7. #67
    Jun 2022
    Thanks i will try
  8. #68
    Aug 2021
    Hi can anyone help with long coding for:
    Seat Ibiza FR 1.4 Tsi DSG , RHD, discs 288/232, TPMS
    the Vin is VSSZZZ6JZAR136012
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
    Component: ESP8.2i front H04 0002
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 04941 000 00000
    VCID: 4D9B7174102FDF762F5-8018
  9. #69
    May 2022
    Ukraine
    I see your ibiza-sport. Knock on the line. I will find time to help and solve your problem. You have a right-hand drive, and a 1.4 engine, a DSG/// box. There's not long to help Va, but we have a war. We kill the orcs, and in between we code even the A0 platform. Knock, in a personal, remove the log of block 03 and I will write you an encoding.
  10. #70
    May 2022
    Ukraine
    Как то так. Можно в Telegram писать, будет быстрее .
  11. #71
    Aug 2021
    Thank you for the reply, hope everything gets resolved for you soon, the situation is truly heartbeaking.
    Yes the car is from GB, not sure what you mean by "remove the log of block 03"
    thanks for your help
  12. #72
    May 2022
    Ukraine
    Quote Originally Posted by ace2000uk View Post
    Спасибо за ответ, надеюсь, что у вас скоро все разрешится, ситуация действительно душераздирающая.
    Да машина из ГБ, не уверен что ты имеешь в виду под " удалить лог блока 03"
    спасибо за помощь
    No. it's a translation problem. you need the whole log, I can see from it that you have DSG, engine software and from it I guess that this is CAVF .....
    We will torture this car without it 130248DB837000B8C82512E3C1D300811700
    In general, you need to buy Ibiza A0 platforms. There the code is 4 times longer))) But we are already counting it. Say hello to Boris Jongson.))))
  13. #73
    Aug 2021
    Thanks Fibiana, yes thats the same code i came up with it accepts the code, but when i go to measuring blocks group 002 i press the ESP button and the parking brake activates, I pull the handbrake lever up and the ESP activates, and the lights wont go off the dash.
    I made a thread about it but didnt name the title very good so have had no luck. i have put logs on there though.. thanks again
    https://www.digital-kaos.co.uk/forum...VCDS-VIN-issue
  14. #74
    May 2022
    Ukraine
    Я не читал эту тему, не читал логи и не понял заданного вопроса. Я взял и написал код. Если есть время, подробно объясните проблему, постараюсь найти решение..
    Когда не понимаю или захожу в тупик, начинаю все сначала. Если хочешь, давай начнем с нуля. Я помогу и сделаю машину. Давайте поподробнее, от проблем и начнем танцевать.
    Послушай снова. Я дал вам код, который вы должны ввести в блок, и дать мне адекватный ответ о том, как повел себя блок. Ваш код мне не интересен, хочу посмотреть как будет работать мой код))
    If you want to be treated, take the pill prescribed by the doctor. I need the reaction and desire of the patient. П
    I did not read this topic, did not read the logs and did not understand the question asked. I took and wrote the code. If you have time, explain the problem in detail, I will try to find a solution..
    When I don’t understand or I’m at a dead end, I start all over again. If you want, let's start from scratch. I will help and make a car. Let's take a closer look, from problems and start dancing. Listen again. I gave you the code you need to enter into the block and give me an adequate answer on how the block behaved. Your code is not interesting to me, I want to see how my code will work))ослушай снова. Я дал вам код, который вы должны ввести в блок, и дал мне адекватный ответ на том, как повел себя блок. Ваш код мне не интересен, хочу посмотреть как будет работать мой код))
  15. #75
    Moderator
    PremierD's Avatar
    Jun 2009
    Last warning, English only please ...........
