Sorry, this is a machine - the browser translates. He wants to translate, and then slows down. My tongue betrays me.
Hi Fibiana,
Right from the start...
I jetwashed the engine and got water inside the ECU, so I purchased an ECU set off ebay.. Clocks, ECU, BCM and Ignition, fitted all these and it drives fine, But in VCDS the ABS module is all Zero's I have inputted your code and it was accepted but I have 2 lights on the Dash the TPMS and skidding car one, In VCDS in ABS,measuring blocks, group 2 when i press ESP button the handbrake activates, and when i pull the handbrake the ESP activates.
I have pasted in the Original scan and the New ECU scan hope they help..
Thank you for this its much appreciated...
ORIGINAL SCAN
Saturday,24,July,2021,20:29:13:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ6JZAR129959 License Plate: K13TDD
Mileage: 94901 Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 4B 56
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAVF) Labels: 03C-907-309-V1.clb
Part No SW: 03C 906 027 AD HW: 03C 906 027 AD
Component: 1.4l R4 TSI H15 9972
Revision: L2H15--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 35214 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027AD 001007
ROD: EV_ECM14TSI01103C906027AD.rod
VCID: 63CFB7CC6AAB7906E91-8036
7 Faults Found:
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 29
Mileage: 152265 km
Date: 2127.14.31
Time: 21:05:19
4667 - Accelerator Position Sensors (G79) / (G185)
P2138 00 [040] - Implausible Correlation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 149417 km
Date: 2127.14.18
Time: 19:16:25
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [096] - De-Energized Performance Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 149417 km
Date: 2127.14.18
Time: 19:16:25
7676 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [104] - Pump Current Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 70
Mileage: 148540 km
Date: 2126.14.29
Time: 14:28:00
4054 - Cylinder 1
P0301 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 70
Mileage: 148540 km
Date: 2126.14.29
Time: 14:28:00
4057 - Cylinder 2
P0302 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 70
Mileage: 148540 km
Date: 2126.14.29
Time: 14:28:00
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 70
Mileage: 148540 km
Date: 2126.14.29
Time: 14:28:00
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 048 S HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2669
Revision: 00043014 Serial number: CU501705107070
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 40855840107D021ED43-5072
No fault code found.
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 130248DB836F00BBC82E12E7C1DA00811700
Shop #: WSC 04941 000 00000
VCID: 4D9B7174102FDF762F5-8018
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 0
Fault Frequency: 29
Reset counter: 157
Mileage: 149054 km
Time Indication: 0
Date: 2063.14.12
Time: 19:34:39
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x3067
Hex Value: 0x13B7
Hex Value: 0x1D7C
Hex Value: 0x7D83
Hex Value: 0x7B00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6R0-907-044.clb
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
VCID: 2241F2C83D31300EA27
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 048100817
Coding: 3C8829E888632500922800007E0B1CC800C0400F608C000020 0000000000
Shop #: WSC 64564 324 38760
VCID: 3E7926B8A98974EEA6F-806B
Subsystem 1 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3130
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3130
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 010000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA05 H09 0018
Revision: -------- Serial number: 003DW00C64G0
Coding: 003035
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 42815248D571100EC27-8017
Subsystem 1 - Serial number: 3496GRB402VCQ048NSLK
Subsystem 2 - Serial number: 3506GRB402BCB77N9SJT
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 901 B HW: 6J0 920 901 B
Component: KOMBI H08 0110
Coding: 710A00
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2757E3DC5E13D526F59-8072
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 422100
VCID: F0E54880235D529EE43-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H08 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 06403
VCID: 2F670BFCEAE38D663D9-807A
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: F0E54880E35D529EE43-80A5
Address 56: Radio
Cannot be reached
End ---------------------------------------------------------------------
NEW ECU SCAN
Tuesday,10,August,2021,20:27:06:65217
VIN: VSSZZZ6JZAR136012 License Plate: K13TDD
Mileage: 93136 Repair Order:
01-Engine -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
Component: 1.4l R4 TSI H10 9972
Revision: L2H10--- Serial number:
Shop #: WSC 00829 210 97507
Readiness: 0110 0101
Coding: 0000020
VCID: 40855840107D021ED43-5000
Revision: --------
Coding: 000000000000000000000000000000000000
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 34
Mileage: 149885 km
Time Indication: 0
Date: 2053.14.18
Time: 00:00:16
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x30EA
Hex Value: 0x149B
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x8000
Hex Value: 0x0000
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 15
Reset counter: 73
Mileage: 0 km
Time Indication: 0
Date: 2063.14.31
Time: 16:18:35
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x10FD
Hex Value: 0x259E
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7D00
Hex Value: 0x0000
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 8
Reset counter: 34
Mileage: 149885 km
Time Indication: 0
Date: 2053.14.18
Time: 00:02:30
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9A
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 34
Mileage: 149885 km
Time Indication: 0
Date: 2053.14.18
Time: 00:02:30
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x1A9A
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Revision: S0000000
VCID: 2241F2C83D31300EA27-8077
Revision: BF046001 Serial number: 0147 057100182
Coding: 3C8829E888612500922800007E0B1CC800C0400F608C000020 0000000000
Coding: 030000
Coding: 020000
Coding: 000000
Coding: 000000
Coding: 000000
Coding: 010000
Coding: 003035
Coding: 410A00
Coding: 422100
Serial number:
Coding: 11221
Shop #: WSC 06403
1 Fault Found:
49-10 - No Communications - Intermittent
Coding: 0000001
Address 56: Radio
Cannot be reached
And the forums do not think for a long time, there is no time. although we are at war and the Russians are destroying cities and towns.
You do not disappear, I will definitely watch the scan. In which the VIN of the ABC block and the engine block is different. VSSZZZ6JZAR129959 and VSSZZZ6JZAR136012
This is where you need to think. And decide how to make fast and cheaper. On your question, I advise you to open a separate topic, I will go there regularly.
Today my head does not boil deeply. And you also need to kick some katsaps.))) A new topic will come in handy. since there will be a change in software and VIN in blocks.
And further it will be necessary to throw scans of block 03, 01 and ... ???)))
ace2000uk (10th August, 2022)
I have just noticed the coding on the Kombi is different on both scans...
but yes I will start a new thread..
Let me know when you open a new thread. I do not understand a little through the translator and words. Scans from blocks are boring for me, I will help you suggest a solution using them. Having created a topic, you should tell everything like a pastor, and the doctor will already accept amputation or treatment according to analyzes))
I'm here, so we'll figure it out and make this car. A very interesting patient. I promise that I will do very well in coding. According to the firmware, I will also connect specialists or give advice from them.
Hi Fibian, I have posted a new thread as requested,, thanks.. https://www.digital-kaos.co.uk/forum...76#post4387876
WVWZZZ6RZAY013824
vw polo 1,6 tdi
ABS Long Code PLEASE
hello ,i need long code
WVWZZZ6RZAY013824
vw polo 2009
1,6 tdi
LHD
I know one turbodiesel polo, 1.6, its block is 2Q0 614 517 N
I can even show you the software. Only code 09035364354490B5CAFCAC1824DB42A649124926444A242444 545254452442659248926422522424222A4A2AA249C64A3D92 6352BC
Looking at the code, it becomes clear to everyone that the car is on the mechanics, has a start-stop, front and rear parking assistant, without XDS. Etc.
Hello! I need your help in order to code my new ABS/ESP module. Because my old ABS module is(1K0 907 379 AA)
Please , help me. I'll give you all the information regarding the car and other stuff...
1. new ABS module is 1K0 907 379 AJ / ESP version:ESP MK60EC1
2. my car's VIN is WVWZZZ1KZ6M745038
3.2006 VW Jetta
4. LHD
5. 1.6 FSI engine, code BLF, manual gear HBM
6.FWD
7.no start/stop system installed
8.TPMS-indirect ABS basesd (no sensors in each wheel)
9.my car have ESP on/off button
10.I think that the new ABS module have the possibility to activate HHC
Thank you very much for your support and answer!
Why write so much? It is possible to be mistaken. We connect the computer to the car and it will perform a full scan. We see the number of blocks, and put it into the calculator, which will give the desired code.
I'll check the information a little later and if everything fits, I'll post a trial code in this thread.
But I suspect that you are deceiving, and decided to quickly make in a car instead of MK60 .... MK60EC1. So?
Last scan of my car .
Thank you
Я понимаю.
Адрес 03: ABS Тормоза Маркировка: 1K0-907-379-MK60-F.lbl
Деталь № SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Компонент: ESP FRONT MK60 0102
Ревизия: 00H13001 Кодировка
: 0002689
Магазин №: WSC 00066 000 00000
VCID: 71E960C368A9130EEC-8024
Код неисправности не найден.
И дайте последний, который с новым блоком.???? Где он длинный?????????
Hello ,
The new abs pump is code 1K0907379AJ
Thanks you !
I wish you good luck and problem solving. If you still have not heard me, then let a friend help.
It's not hard to buy and install, it can be harder to get it to work right. And you always have to think ahead. This will be a lesson to anyone who asks questions about coding.
When I asked for a full scan of the car, they still offered me the block number))).
I will tell you more. that you do not have indirect TPMS, it is on the radio channel, with sensors.
It will be interesting for me to follow the development of events, as soon as there is a final, I will connect and help. For me, the topic with this car is closed.
Like Fabia in the next topic.
