Page 8 of 10 FirstFirst ... 345678910 LastLast
Results 106 to 120 of 148
  1. #106
    Feb 2023
    If I want to download this calculator, do I need to post in this thread, or just any thread? Sorry, just signed up today.
  2. #107
    Aug 2019
    Romania
    Helo, can you help me with short coding
    Hello! I need your help in order to code my new ABS/ESP module. Because my old one was broken (1K0 614 517 AD) I replaced it with second hand one.
    1. second hand ABS module is 1K0 1K0 614 517 J (on module picture) / ESP version:VCDS scan shows 1K0 907 379 K ESP MK60
    2. my car's VIN is TMBGE61Z752024582
    3.2006 Skoda Octavia II
    5. 2.0 TDI engine, code BKD, manual gear
    6. FRONT DRIVE
    7.no start/stop system installed
    8.TPMS-indirect ABS basesd (no sensors in each wheel)
    9.my car have ASR/ESP on/off button
  3. #108
    Jul 2023
    Hi, greetings from Argentina. I need some help,
    My car was rob and i lost the long code of abs module.
    Could someone share the long code of the abs module?
    PN:5U0614117L
    Component: EBC460 ABS H03 0120
    VIN: 9BWAB45U2HP084719
  4. #109
    Jul 2023
    can anyone help me abs coding
    lost its code since having problems with electrics
    audi a3 1.9 tdi 2009 manual gearbox
    no cruise control
    no start stop
    esp button on and off
    rhd
    vin wauzzz8p69a150296
    1k0 907 379 cd esp mk60ec1 h35 0120
  5. #110
    srt8's Avatar
    Nov 2017
    HI all, 2013 ABS LONG CODING help needed. VW GTI 1K0-907-379-60EC1F. Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152 WVWGD7AJXDW016308 WVWGD7AJXDW016308
    the coding is zeroed. will pay for a good solution. thank you in advance VIN# WVWGD7AJXDW016308
    WVW
  6. #111
    Jun 2017
    Germany Stuttgart
    Default ABS-ESP long code VW Polo 2010
    Hello! Can someone help me with a long coding of: VW Polo 6R0 907 379 R- ESP 8.2i before H04 0002 -WSC02069 Only zeros, no code. Vehicle VIN: WVWZZZ6RZAY161346 I am not looking for free help. Engine code: CAYC. full scan in attachments:
  7. #112
    Nov 2009
    poland
    Hey can you help me with short coding Hi! I need your help in coding my new ABS module
    1. The ABS module used is 6R0907379EB ESP 8.2i
    2. My car's VIN is VSSZZZ6JZDR080892
    3. SEAT IBIZA 2009 5. 1.2 TDI engine, code CFW, manual gearbox
    5. FRONT DRIVE
    6. no start/stop system installed
    7. My car has an ASR/ESP on/off button
  8. #113
    Dec 2016
    hi guys
    need long codage vw golf6 2tdi CBA
    1K0 907 379 AE H35 0104
    no frein automatic
    LHD
    VIN/ WVWZZZ1KZ9P407346
  9. #114
    Jun 2022
    Hello
    Have a problem with caddy van its 2013
    Someone putted 2.0tfsi/tsi engine from eos
    car has 1K0907379BK ESP MK60EC1 module
    Vin I believe from eos WVWZZZ1FZ6V008152
    Is it possible just code it as Engine is from 2007 and esp is from 2013 or need to reflash abs to older version?
  10. #115
    Apr 2021
    Quote Originally Posted by rayssant View Post
    Theoritically possible. But not with settings matching to the actual vehicle, which is a Caddy. In case you write an EOS coding (which is obviously the only thing you can do with this VIN), vehicle might behave weird when braking or driving "unusual". Possible though. Think it's better to get the VIN matched to caddy original chassis and then write coding matching to caddy (as good as possible, since there was no gas 2.0 engine in caddy I guess). In that case the mismatches are less than going with EOS setting.
  11. #116
    Jun 2022
    Quote Originally Posted by r4nd0mize View Post
    Can you help with it?
    not for free of course
  12. #117
    Apr 2021
    Changing VIN: no. About everything else it needs a closer look. It's possible to fix this though. If you still need help we can go for it but please send me a message.
  13. #118
    Oct 2023
    1. ABS module is 1K0 907 379 BS (on module picture) / ESP version:VCDS scan shows ESP MK60EC1 H46 0166
    2. my car's VIN is TMBKJ73T8F9039556
    3.2015 Skoda Octavia II
    5. 1.6 TDI engine, code CAYC, manual gear
    6. FRONT DRIVE RHD
  14. #119
    Feb 2020
    RO
  15. #120
    Feb 2010
    Bulgaria, Sofia
    Good afternoon, need help with
    Audi A3 8P 2009 , ESP
    1K0 907 379 AD MK60EC1
    lost coding after washing the interior of the interior, the dashboard failed for a few days until we dried the moisture in the passenger compartment.
    1.9 TDI , Left-Hand Drive ( LHD )
    Brake diameter Front : 280 mm , Rear : 253 mm
    NO TPMS button under radio , but Tire Pressure Monitoring No Signal/Communication in CAN Gateway .
    Attach VCDS Log and PR Lable.
    Solved, the calculation of 17 and 18 bytes turned out to be a problem
