Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 99
    DK Veteran vevepatronu's Avatar
    Jun 2009
    Romania
    Default VAG-COM VCDS 812.4 to 805
    Another thread today... i have a vagcom 812.4 that for some commands ask me for activation of the software, i think this issue is from the bad dump that has inside it... I want to downgrade it because 805 is more stable. Can anyone please help me with a dump (805) for it and a method how to wright it?
    Thanks!
    racin-snake's Avatar
    Jun 2009
    you have to activate the first time you use it plugged into a car is it a first install ?
    Jun 2009
    Romania
    Quote Originally Posted by racin-snake View Post
    the interface works, i can see parameters, can see dtc... but some futures asks for activation...
    Quote Originally Posted by vevepatronu View Post
    Thanks!
    pliz send me sw 812.4
    i try help to you
    fantomel's Avatar
    Mar 2009
    Us
    There is no use for that, the firmware in chip atmega162 it's bad, that's why your interface apears as shareware at some diags, you have to rewrite atmega162 chip with a programmer.Here are schematics, software and dumps for vcds 805 : http://s4.transfer.ro/storage/VCDS_805-6ad62.rar
  6. The Following User Says Thank You to fantomel For This Useful Post:
    estwood68 (10th April, 2014)
    Member roby's Avatar
    May 2009
    Jupiter
    I think you don't have the right VCDS software and i think you have shareware version of soft not the full one,but you can check that by the following: (enter in first screen of VCDS in Options and check there if your interface has a hex-key and if it's fully registered and activated) if it is without key then your soft is only trial version.
    Jun 2009
    Romania
    Quote Originally Posted by fantomel View Post
    i can say thanks my friend but let me test it and will post the result... thanks
    It seems that the previous link to 805 firmware is no longer available... Can someone who downloaded it upload it again or send to me? I have the same problem with 812.4 beta that it claims that the program is shareware/unregistered.
  10. #9
    Hi Fantomel, just tried that link and its in a language I don't understand!
    Any chance Of some help here please?
    Rgds ES
  11. #10
    Apr 2009
  12. The Following User Says Thank You to jonniebravo For This Useful Post:
  13. #11
    Member basco's Avatar
    LONDON
    HI JOHNNIE BRAVO I,VE GOT THE SAME PROBLEM WITH MY VCDS 812.4 SOFTWARE AS WELL IT KEEPS COMMING UP AS NEEDING A LICENCESED INTERFACE .KIND OF PISSES YOU OFF WHEN YOU'VE GOTALL THE BUTTONS ON SCREEN HIGHLIGHTED BUT WHEN YOU CLICK ON IT FOR INSTANCE,"OUTPUT TESTS" YOU JUST GET THIS IRRITATING ERROR MESSAGE TELLING YOU THAT YOU NEED A LICENCSED INTERFACE. ANY ONE GOT A WORKING VCDS 812.4 OR 805 SOFTWARE COULD YOU PLEASE SEND ME THE LINK OR THE SOFTWARE ITSELF .THANKS GUYS
  14. #12
    I have been board tonight so i thought i would have a play around
    uninstall your software but leave drivers.
    Download the following links
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Replace the keyGen protect file with this one
    This will allow you to create your own licence file but you will need to know your Hardware ID XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXXX.
    Run the keyGen, select licence manager, add licence ,
    Enter name, company, Hardware ID and then click generate licence at the top, you will see a new file in the KeyGen protect file .
    Copy the content (not the file) to the VCDS-Release-8050 file
    Then go back and copy the 4 other files from the same file as the keygen to the VCDS-Release-8050 file
    Before you run the software i suggest that you disconnect from the INTERNET other wise i think you interface will be damaged
  15. #13
    will above keygen and vcds 805 work with an clone version 704 interface or do i have to flash the interface with newer firmware. Does any have firmware dumps to share.
  16. #14
    Thanks I have a 812.4 unregistrered and now work well with 805.0.
    Is there any way to do the same thing with 812.4 version of software?
  17. #15
    Aug 2008
    it is necessary to unlock the 908 version?
    if so, how.
    namely, it is because that the serial number appears only at connection to a vehicle.
