hi i have problem after dpf off i did with ecusafe program ,no folts ,engine roning good but when i start 1 time in morning rpm only 3000 torn off,start again then ok ,any idea
there original file please help edc 16c34 9658274680 bosh nr 0281011633
try this one, work 100%
regards
marwan akram (7th July, 2015), mossa19 (2nd January, 2017), ZYGI66 (3rd December, 2014)
Had Picasso with the same problem, ECU safe does not work good on these, Volta is better
Anyway had to program configuration with PP2000/Lexia, it was lost somehow.
Connect to engine ECU with PP2000 and check if the configurations are not lost.
BR
i put that file same story program ijectors still same yes i have folt ( configuration not carried out intermittent) i have lexia but if i go to configuration it asking some code to aloud do this what else i cane use insted lexia
Hi.programming code 03114
my file dont work?
thanks but same story
seem to get these config problems with peugeot edc16 allot, when doing dpf off ,etc strange faults to do with esp light on Permanent fault etc. normally diagbox resets and all is ok, seems linked when u do egr off with volta i find, and sometimes inj codes gone, BDM all the way, problem is cost time and cheap shit french car, so obd always 1st option , cheaper but is it in the end ? = Time
my file works 100%, maybe you have mess with settings in ecu.
configuration was not ok thanks for help
