How do you need help? How far have you got? What have you tested?
Or do you just want a free meal?
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
I,m learning, edc16 sorted out how to remove egr but no edc17. I,m just started with this. Previosly did just dashboards.
On edc17 is similar way to remove egr like edc16 maybe that can help you.
Best regards
Cleared 6 hysterisis maps to 00000, EGR off and problem solved. Thanks for tips.
Hi...i have a problem with six Hysteresis maps...because after the egr off,car (golf 6 2.0tdi 143hp edc17c46) do continuous regeneration..and i hear same problem for another users....very strange
man you shouldn't set to 0 all 6 maps
and how i must do? hysteresis (theorically) shut-off with this way,but is not...i try to write obd ori file and regeneration stops
yes man that is normal with orig file
I confirm , I too have the same problem
Yes,but i must close egr because find error P046C: implausible signal egr....all ori,car not regenerate..with egr off try always to regenerate,write smoke and rest at 1.100 rpm (regeneration mode)
Inviato dal mio iPhone utilizzando Tapatalk
Anyone have solution under payment?
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
