Results 1 to 4 of 4
    Jun 2009
    CZ
    Default Ford Mondeo 147kw edc17cp42 / dpfOff need help
    Dear all, have mondeo 2.2d 147kw edc17cp42 need help with dpfOff, swiftec switch solution dont work for me after 50km have 5 errors car without power... see att. thank you for help Wok.
    5 CMDTCs found!
    P244C:00-6C Catalyst Temperature Too Low During Regeneration, Bank 1
    P2453:00-EC Diesel Particulate Filter Differential Pressure Sensor Circuit Range/Performance
    P2463:00-AF Diesel Particulate Filter - Soot Accumulation
    P246B:00-2F Vehicle Conditions Incorrect for Diesel Particulate Filter Regeneration
    P246C:00-AF Diesel Particulate Filter Restriction - Forced Limited Power
    LaraVAG's Avatar
    Jun 2011
    Disable this dtc if you have swiftec
  3. The Following User Says Thank You to LaraVAG For This Useful Post:
    wokounek (29th November, 2014)
    Jun 2009
    CZ
    Hi, solved with disable dtcs regards Wok.
    Could you send the solution with DTCoff?
