Results 1 to 12 of 12
    Aug 2013
    Default CITROEN C5 2,2 HDI FAP 170CV REMAP PROBLEM
    Hi all, i have a problem with one remap. I do a dpf off and tune one Citro?n C5 2,2 HDI FAP 170CV, with edc16 c39. After do it, sometimes , at mid charge, light on the check engine light, and the dtc error are P0234 overboost . Can someone revise my map? Please, i need a solution. Thanks.
    CITROEN-C5-2.rar
    CITROEN-C5-DPFOFF.rar
    Oct 2012
    P0204 on PSA is a fault of wiring of 4-th injector
    the mod file have not fap dpf off...is only a "power" remapp
    first of all try to rewrite the original file into your ecu and see if the error dtc persists
    if all is ok,contact me for sollution
    Aug 2013
    The fault is very dificult to reproduce
    Aug 2013
    Quote Originally Posted by betrescudan View Post
    Sorry, the error code is P0234 oberboost. I write it bad.
    Oct 2012
    Quote Originally Posted by alexlargo27 View Post
    so mate...you have a bad mod file...the turbo maps give you thoses errors...you need restore to original map,try with the original if the probblems persist,and if is all ok,you will contact me for a good remapp for your car...regards
    did you have the fap phisically canceled from your car?
    Aug 2013
    Yes, is phisically canceled
    Oct 2012
    did you tested the car with the original file?...same errors?
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    CITROEN-C5-2.rar
    Small correction: you mod file uploaded is WITH DPF_OFF!
    regarding remap - better first contact the person who did the mod. In case was done by you than better ask somebody who knows how to do it correctly.
    Oct 2012
    Quote Originally Posted by mishu_b View Post
    1AEFA2 is a bad try to do dpf off on This car mate....1 bit not work here...and is not dpf there mate
    Jul 2009
    Land of Choice!
    no - I'm not talking about that mod.
    there is something else mod which ensure DPF_off
  11. #11
    Oct 2012
    well,is a secret?you want to help or what?
  12. #12
    Jul 2009
    Land of Choice!
    just think and a nalyze the files .....
    once you told to the owner the file is incorrect DPF-off it is supposed that you a nalyzed it!!!
