Results 1 to 11 of 11
    Dec 2014
    Default What do I need to post to get key code - Peugeot?
    Hi, I'm confused (not an unusual problem with me!).
    I can see lots of posts asking for help decoding key codes from VIN numbers, and it's obvious I need to supply a data dump of some sort, not just a VIN.
    I can't find a guide anywhere on here (I have searched but probably missed it), so can someone please let me know what I need to do?
    I have a diagnostic unit (PP2000) on its way so will be able to read data soon.
    Car is Peugeot 307 and I want to code a new key immobiliser (virgin chip).
    Thanks,
    Robin.
    Apr 2010
    Quote Originally Posted by RMSpug View Post
    Thanks,
    Robin.
    For immo login code you need bsi dump or pay to codes dealer by Vin number
    Dec 2014
    What is a bsi dump - is it something I will be able to read with the PP2000/Lexia diagnostic kit when it arrives?
    I'm assuming the immo code is what I need to program a new key?
    Apr 2010
    This discussion will going to be a big loop and hard work so I can only say to you to start read and search for info.
    Good luck
    Jul 2010
    west mids, uk
    you need to remove bsi, locate eeprom, remove it and read it with a programmer, then post results here.
    Some of this bsi you cannot reach eeprom easily, you will need to search on DK for solder points to read.
    If all of this is betond you, try 3D group or similar for PIN to VIN service.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  6. The Following User Says Thank You to ninja123 For This Useful Post:
    RMSpug (1st December, 2014)
  7. #6
    Dec 2014
    Quote Originally Posted by ninja123 View Post
    ninja
    Ah, so my diagnostic kit won't help me here then.
    Thanks for that - I'll have to try elsewhere to see if someone can decode my VIN for the code.
  8. #7
    Dec 2014
    Quote Originally Posted by totalkey View Post
    Good luck
    But that's the point - I have been reading posts on the forum for hours and not found the info I need to post.
    Perhaps an 'Idiots guide' might help newcomers like me?
  9. #8
    drakov's Avatar
    Aug 2008
    Take logbook and id>goto dealer>pay dealer>get code, cheaper that way than buying programmers ect for what sounds like is a one of job, not knowing what your doing could easily result in yuo visiting dealer and spending a few hundred pounds
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  10. The Following User Says Thank You to drakov For This Useful Post:
  11. #9
    lion0304's Avatar
    Oct 2014
    Thanks,
    Robin.
    In you case, i forget to do by myself. Because:
    1/ ?f you want program key or remote, you need tools. Many tools
    2/ All car need the Pincode to Unlock the ECU, that way car will accept new keys or remotes.
    3/ You need tool to procode the virgin chip, if no precode, your key can't work.
    4/ To have Pincode, you can buy online service, Peugeot dealer need pay or by youself (this case we know and members tell you what to do in your case with knowing or not).
    So, if you want to learn, you need to read, read and read (i think your hours aren't enough because you don't know what's BSI or immobox......)
    If you want just add key or remote for your car, you can pay someone do it ( it's a cheapest way to have new key working for you). In your situation, playing with a car will cost you expensive. That is the fact and reality.
    Skill need to learn by months ans years. Not hours.
  12. #10
    Dec 2014
    The point is, I have the tools to unlock the ECU to accept new keys (PP2000, Lexia 3 dealer diagnostic kit) and a key with a virgin immobiliser chip just waiting to be programmed.
    All I need is the PIN / Key Code decoding from my VIN as I did not get the security card with PIN with the car.
    I thought it would be easy to get the PIN - someone on the Peugeot forum advised me to ask on here saying someone would probably be able to decode it for me.
    I'm not interested in remapping the ECU or anything like that - just adding a virgin key to my car.
    When I said I had been reading the posts for hours, it is not so that I can learn everything, I was just trying to find out what info I needed to post so someone could decode my VIN.
    I will leave the more complicated tasks to those of you who have been doing it for years and who already have the skills
  13. #11
    Moderator
    PremierD's Avatar
    Jun 2009
    Read the BSI ... or go to the stealer mate .. that's your options .......end of story ... closed
