Hi guys got problem with my original avdi which some time works fine but vag camander has stoped working I had reinstall windows to fix this problem which happens quite often is there any other solution to it please.
Pic and Log file Attached
contact avdi customer support my phone and not mail
only send attachment tru mail and call for quicker response
cheers
311786 (29th December, 2014)
is it only vag commander sw or all the softwares?
mine works fine..i use vag all day
Abrites ,full package
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
pay the price ...go original always works better......
Its Ok for me too, working perfect every day.
probably is a conflict with some drivers wich your laptop is using ? could be because of the brand of the laptop ? what laptop are you running avdi on ?
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Sorry for Late Reply.
It causes Problem on every laptop I installed on so far tried three Different laptops only the Vag commander Causes this issue. when reinstall window and software again work fine for about two weeks than back again. only solution I have atm is to reinstall window every time get problem.
thank you gus for reply.
last update I have 13/12/2013
For me everything work fine (odo,pin,login code...) except error erase ?!?!
Cant erase errors after make odo correction .
311786 (30th December, 2014)
i also had some issue on w7, on xp all is working fine.
I had issue coding key for a4 bcm but after Nov update all okay they will sort it on the next update bit let them know
Please help stamp out this disgusting trade.
JUST SIGN THE PETITION .....PLEASE
https://savedogs.soidog.org
TULGYWOODMAN you r rit.
I also have a possible bug after november update , I can't install the latest update, the installer stops with an error after approx. 10 seconds , I have tried on 4 laptops and the same error. Anyway, the interface work ok an all avdi products, but can't benefit on the latest update.
