Results 1 to 14 of 14
    311786's Avatar
    Jun 2010
    Default Abrites Avdi Vag commander Issue With windows.
    Hi guys got problem with my original avdi which some time works fine but vag camander has stoped working I had reinstall windows to fix this problem which happens quite often is there any other solution to it please.
    Pic and Log file Attached
    Dec 2014
    Nigeria
    contact avdi customer support my phone and not mail
    only send attachment tru mail and call for quicker response
    cheers
  3. The Following User Says Thank You to uresh For This Useful Post:
    311786 (29th December, 2014)
    Top Poster saka112's Avatar
    Sep 2011
    is it only vag commander sw or all the softwares?
  5. The Following User Says Thank You to saka112 For This Useful Post:
  6. #4
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by saka112 View Post
    If you have last update from November it is BUG in some interface(only VAG) and solution after holidays , again BUG FIX
  7. The Following User Says Thank You to cokolo For This Useful Post:
  8. #5
    Dec 2008
    SOUTH AFRICA
    mine works fine..i use vag all day
    Abrites ,full package
    Carprog
    Dajavue
    Zedbull
    orange 5
    Tango
    Vag-com
    Vag Tacho
    Vag Dash can
    Vag Can pro
    Magpro 2 X17/ FLEX
    VVDI PROG /MB PROG
    pay the price ...go original always works better......
  9. The Following User Says Thank You to audivwauto For This Useful Post:
  10. #6
    pepi's Avatar
    Jan 2010
    Its Ok for me too, working perfect every day.
  11. The Following User Says Thank You to pepi For This Useful Post:
  12. #7
    bursuc's Avatar
    Oct 2011
    inside MCU
    probably is a conflict with some drivers wich your laptop is using ? could be because of the brand of the laptop ? what laptop are you running avdi on ?
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  13. #8
    311786's Avatar
    Jun 2010
    Sorry for Late Reply.
    It causes Problem on every laptop I installed on so far tried three Different laptops only the Vag commander Causes this issue. when reinstall window and software again work fine for about two weeks than back again. only solution I have atm is to reinstall window every time get problem.
    thank you gus for reply.
    last update I have 13/12/2013
  14. #9
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    For me everything work fine (odo,pin,login code...) except error erase ?!?!
    Cant erase errors after make odo correction .
  15. The Following User Says Thank You to cokolo For This Useful Post:
    311786 (30th December, 2014)
  16. #10
    i also had some issue on w7, on xp all is working fine.
  17. The Following User Says Thank You to chriskross For This Useful Post:
  18. #11
    Jul 2010
    dewsbury west yorkshire
    I had issue coding key for a4 bcm but after Nov update all okay they will sort it on the next update bit let them know
  19. The Following User Says Thank You to dashtec For This Useful Post:
  20. #12
    Dec 2009
    Prussia
    Quote Originally Posted by 311786 View Post
    You haven't updated for a year?????????
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  21. #13
    311786's Avatar
    Jun 2010
    TULGYWOODMAN you r rit.
  22. #14
    calin_bm's Avatar
    Jan 2010
    near civilization
    I also have a possible bug after november update , I can't install the latest update, the installer stops with an error after approx. 10 seconds , I have tried on 4 laptops and the same error. Anyway, the interface work ok an all avdi products, but can't benefit on the latest update.
