Results 1 to 13 of 13
    DK Veteran sosmecano's Avatar
    Oct 2010
    PROG
    Default digiprog 3 problem
    I have been using Digiprog 3 for one month. The tool used to work well. But today, when I tried to use it to correct mileage for an golf 6 and golf 5 2008 ford focus 2007......, a window popped up, saying ?ERROR NO CONNECTION .
    only god can judge me
    Check d connector on box for dry joint
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Poss the cconnector on ST16 cable
    Oct 2010
    PROG
    i have cheke my conection cable st16 and ok
  5. The Following User Says Thank You to sosmecano For This Useful Post:
    teerak2uk (6th December, 2014)
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Contact seller
    Oct 2010
    PROG
    Quote Originally Posted by teerak2uk View Post
    Contact seller
    I NEED HELP FROM FORUM dk NOT THE SELLER
    gwee's Avatar
    Dec 2012
    unknown
    i am not god, but is rude to post with cap on !!
    Oct 2010
    PROG
    Quote Originally Posted by gwee View Post
    why do you say that ? that note i'm talking about .......
  10. #9
    Moderator
    PremierD's Avatar
    Jun 2009
    If you leave your CAPS LOCK on it looks like you are SHOUTING ... which is NOT the way to get help mate ........
  11. #10
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by sosmecano View Post
    Maybe just cut off do connector and replace then try my cable on first digiprog was same
  12. #11
    Prussia
    I have been using Digiprog 3 for one month. The tool used to work well. But today, when I tried to use it to correct mileage for an golf 6 and golf 5 2008 ford focus 2007......, a window popped up, saying “ERROR NO CONNECTION .
    DID IT NOT OCCUR TO YOU TO CHECK THE LEADS, THEN CHECK THE CAR OBD SOCKET BEFORE POSTING?
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  13. #12
    Oct 2010
    PROG
    Quote Originally Posted by TULGEYWOODMAN View Post
    i have tested obd cable with multimeter and all connection is ok
  14. #13
    dave11674's Avatar
    Florida, UK
    may be the OBD cable is fluffed mate, is ther enot circuit board in the end of the obd lead ???
    dave
    Digiprog3 Main Testing Cable Digiprog III OBDII Cable
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
