Results 1 to 9 of 9
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default W220 EZS Key generate HC05 - 0G47V
    Hello guys,
    Can anyone please generate keys - Big Old Motorola (233.186.051A) from this dump?
    Regards,
    Sima
    gwee's Avatar
    Dec 2012
    unknown
    motorola number?
    567 xxx xxx / 65x xxx xxx
  3. The Following User Says Thank You to gwee For This Useful Post:
    simaservis1108 (7th December, 2014)
    Aug 2013
    Serbia,Belgrade
    There is some white factory stains across chip
    I think 567 880 051
    gwee's Avatar
    Dec 2012
    unknown
    ok, u will need 051 keys, calculating now, 10 mins
  6. The Following User Says Thank You to gwee For This Useful Post:
    malczykos's Avatar
    POLAND
    In atachement are your keys.
    18B1B0D3.zip
  8. The Following User Says Thank You to malczykos For This Useful Post:
  9. #6
    gwee's Avatar
    Dec 2012
    unknown
    use the 051 keys only
  10. The Following User Says Thank You to gwee For This Useful Post:
  11. #7
    gwee's Avatar
    Dec 2012
    unknown
    your car might not start with the same mcu, since you need to heat it to read
  12. The Following User Says Thank You to gwee For This Useful Post:
  13. #8
    puiu's Avatar
    Timisoara
    Quote Originally Posted by gwee View Post
    The problem with the heating the MCU is just for pass RAM test in ETL programmer,in EZS is working fine ,
    at least from my experience with this ,never had problems after i made keys...
    is not the same with the HC08 - if this one must heat up for reading ten 100% must be replaced
    puiu
  14. The Following 3 Users Say Thank You to puiu For This Useful Post:
    gwee (7th December, 2014), HeXeN (7th May, 2020), simaservis1108 (7th December, 2014)
  15. #9
    Aug 2013
    Serbia,Belgrade
    Thanks to all,I will test and report
