Page 13 of 15 FirstFirst ... 389101112131415 LastLast
Results 181 to 195 of 220
  1. #181
    Oct 2013
    Hello.
    Can you share ept file for FTDI chip? I reprogramed atmega via TL866A but unfortunately "device is silent"
    When I conncected to MPROG3.5, my FTDI is blank.
    I tried put EPP to 93c46 but my TL866A cant read and write this chip.
    thanks a lot.
  2. #182
    Apr 2012
    Wonderland
    where to find adobe reader 10?
  3. The Following User Says Thank You to atomiczen For This Useful Post:
    Youneselm (4th January, 2017)
  4. #183
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by atomiczen View Post
    adobe.com .
  5. #184
    Nov 2015
    Show me tell me the program window is unregistered and shows the status bar and then says there is a error please help me
  6. #185
    can anyone tell me how to connect beeprog+ to xprog and how to configure fuse for programming it ?
    Thank
  7. #186
    Ahmy501's Avatar
    Jun 2016
    Anyone know how to set Fuse and lock on Orange5.
  8. #187
    Ahmy501's Avatar
    Jun 2016
    Quote Originally Posted by Ahmy501 View Post
    Pictures are attached for orange5 fuse N lock options, i need help in setting`em up.
  9. #188
    Ahmy501's Avatar
    Jun 2016
    I have managed to update it to 5.5.1 with success i have all the authorization i tested HC11 and tried to read it as MC68HC11E9 with security bit i get an error message that says "XPROG-m hardware supply voltage too low Check XPROG-m power supply" anyone experienced this issue after an update??
  10. #189
    hass42's Avatar
    Aug 2012
    USA
    Ok, I need help.
    I had this software working fine in my computer and my HDD failed.
    I had a friend install new HDD and had lost all my programs and files.
    I am trying as I did before to install and wont work. I have box all setup but I can seem to
    get my computer to install FTDI drivers.
    I have tried almost everything... Anyone with advice?
  11. #190
    narkeleptk's Avatar
    May 2017
    USA
    Is this LA's version or a differnt one?
    Hass42:
    go to original xprog site and dowload drivers.
  12. #191
    Quote Originally Posted by Music73 View Post
    Found Fault..
    Make Sure To Disconnect From Programmer ..
    The 2 GND pins being shorted together stops the Atmega from functioning.
    DOH...
    Had Another problem getting it to update kept showing hardware as "------------" but tried differant computers and differant usb lead and low and behold it all worked..
    So have now updated my other Xprog with no problems what so ever...
    Cheers and i hope my experience has helps someone else..
    Same with me, after programming ATMEGA, desolder all cables from PCB and all works.
  13. #192
    dragoshu's Avatar
    Aug 2016
    Dacia
    Hello guys,
    I have problem updating my Xprog 5.0 to 5.5 ,I think I do somting rough with following steps,right atmega,set fuse box,right flash,program lock bits.I try to wrought Atmega64 with upa 1.3 without error.
    Can someone guide me witch are exactly are the steps to get back to work my xprog?
    Regards,
    If I help you dont forget to push thanks button
  14. #193
    May 2017
    algeria
    Hi To all....
    im new in this job and i recive my first box Xprog-m v5.72 Cloned .
    the problem the box ask for ""x_requstion_file .dat "" we need to pay for this activation or what ?
  15. The Following User Says Thank You to MagicProg For This Useful Post:
    taxo1965 (16th January, 2018)
  16. #194
    Feb 2013
    You can lay out the software V5.72?
  17. #195
    May 2017
    algeria
    let me slove my probleme and i will opload it OK !!
