Yes because TL866 is produced in two options - with and without isp
Is it working with orange 5 ?
Any one know the diagram please?
Mine is xprog box
Thanx in advanced
sent from LG_G2
Actions speak louder than words
Hi all friend
you must programmer step by step ,i used with USB-UPA:
1. Erase chip atmega 64
2. Program eeprom , Flash
3. Set Lock bits and fuse bits. Program lock bits, fuse bits.
4. Copy Xprogbox 5.51 to C:\ and run Xprognew.reg
5. Run XprogDesktop.exe and update .
alle bmw (29th January, 2019), asliyucegsm (25th April, 2015), esobrino9 (29th December, 2020), jaelgti (26th December, 2014), no__name (23rd December, 2014)
Any one know how to set fuse with orange5?
sent from LG_G2
I reapir my xprog in this way.
I use UPA-USB Device Programmer v1.2 to repair my xprog
1. Earse Chip (Atmega64)
2. Lock Bytes all True Before Programming and fuse bytes like in photo fuse.jpg
3. Write Flash
4. Write Eeprom
5. After write flash and eeprom configurate Lock Bytes see photo lockbytes.jpg
Merry Christmas
audiotek (28th December, 2014), BradyAus (21st October, 2018), jaelgti (25th December, 2014), pablobonome (23rd May, 2015), xseva (10th September, 2018)
This can work with atmega128 ,is spoiling my ATmega64.
thank you good work
sarigol45 (23rd January, 2017)
i have error during installation software ...
you must connect xprog to computer before runing soft installation ?
No, the program runs without connection Xprog too.
I left fuses as it before programming and set locks, working great , thanks adam.
Test it on cas2 white ,read write eep and flash ok .
Test it on MC68HC05B6 stock on bypass security!!
mexanico1971 (20th November, 2022)
Thanks Adam, my old xprog-m 5.0 now have the 5.51 version succesfully installed!, I already tested with Infineon xc23xx, Mac7242, SPI, I2C, Microwire eeproms, some 9S12, HC11, HC05 and TMS. Works great, verify error also fixed with update. Before this update I can't read/write the HC05H12, now it's working!. All authorizations activated.
Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
Hello.
My Xprog not working properly, do not report Hardware ID is ---------------------- and I can not run anything with auth 24.
Update with version 5.0, was programming ISP mkII several batches and still the same.
nn.
no links to members sites in sigs
I had the '--------------------' hardware ID when I made the mistake of having the MOSI pin wrongly connected when programming the Atmega64. No errors in programming and no errors when updating the firmware. When I eventually sobered up a bit and connected everything correctly and re-programmed it all worked.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
no__name (31st December, 2014)
