Page 4 of 15 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 218
  1. #46
    Aug 2010
    Polska
    Hello.
    Solution Dunker gave me, but the problem was in the same programmer. I used MKII isp, now programmed ATmega 64 UPA-USB and immediately appeared Hardware ID.
    I greet and thank no__name.
    no links to members sites in sigs
  2. #47
    I have problem with my XPROG.
    After update I have all autorization but when I try read or write device I got error "Unknown command. Software error"
    like on picture.
    Any Help please?
    Best Regards
    Darek
  3. #48
    Aug 2010
    Polska
    Software must be in c:/ ,update .reg files ,reprogram Atmega 64 . I have similar problem .
    nn.
  4. #49
    Ireland
    1 Program EEprom
    2 program Flash
    3 Lock bits -Program
    4 Fuse Bits Program
    Happy Day.
  5. #50
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    Quote Originally Posted by robert54 View Post
    1 Program EEprom
    2 program Flash
    4 Fuse Bits Program
    Happy Day.
    Lock bits -Program - it is a last operation
  6. #51
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    This solution works OK.Tested tonight.
    Anyone who has problem with fuses and bits,post picture of your programmer options,I help you.
    Regards,
    Sima
  7. The Following User Says Thank You to simaservis1108 For This Useful Post:
    sv2hqx (6th January, 2015)
  8. #52
    ttzag's Avatar
    digital-kaos
    Today i read flash for cas 3 xprog read it as 2048kb it should 512kb ,,any opinion please ?
    sent from LG_G2
    Actions speak louder than words
  9. #53
    tehnosoftex's Avatar
    Romania
    This is normal for xprog. Rosfar on the other side read only 512k and is correct also. Xprog use the whole range of addresses for this mcu from 0 to 1FFFFF, despite the fact that only some blocks are used. The unused blocks are filled with FF. Rosfar use only the blocks that contains data hence only 512k is produced.
  10. The Following 4 Users Say Thank You to tehnosoftex For This Useful Post:
    BradyAus (21st October, 2018), cocutanu (12th January, 2015), igorr (12th January, 2015), ttzag (11th January, 2015)
  11. #54
    ttzag's Avatar
    digital-kaos
    Thanx
    And what if i need to write other flash with 512kb?
    sent from LG_G2
  12. #55
    Romania
    I made a script for upa to convert from one to the other format.
  13. The Following 12 Users Say Thank You to tehnosoftex For This Useful Post:
    adam28 (12th January, 2015), cocutanu (12th January, 2015), DashProg (14th August, 2015), giovani (16th June, 2016), HeXeN (4th March, 2015), iamfooser (2nd September, 2015), ista74 (13th April, 2015), MAYQUAD (8th February, 2015), mohamedkey (11th June, 2015), nanux (12th January, 2015), rtbdiagnostic (11th August, 2021), shanektm450 (7th March, 2015)
  14. #56
    ttzag's Avatar
    digital-kaos
    can u tell me how to use this script please ?
    i read flash with xprog ,its 2048kb , and need to write another one with 512kb
    thanx again
  15. #57
    'write another one with 512kb', and by Xprog? If so, just use it the read 2048kb dump.
  16. #58
    Romania
    Quote Originally Posted by ttzag View Post
    thanx again
    You will need to have upa 1.3 installed but no need to be plugged in. Load your dump in upa and use the script to convert your dump. The script has 2 choices, convert from rosfar to xprog or convert from xprog to rosfar, then you must save the converted dump. It is easy to use.
  17. The Following 2 Users Say Thank You to tehnosoftex For This Useful Post:
    garagetech (26th January, 2015), mikroel (19th May, 2016)
  18. #59
    Dec 2010
    Default awakening atmga64
    I had problems with security bits
    I'll try to wake
    report results
  19. The Following User Says Thank You to jaelgti For This Useful Post:
    pollito128 (21st April, 2015)
  20. #60
    Aug 2013
    Serbia,Belgrade
    To prevent atmega brick do not touch JTAG and SPIEN fuses.
    Also this firmware has bugs.
    For example,if you got an MCU that hangs on bypass security,when you press cancel,the windows program is cancelled but the programmer is still doing bypass security.
    To get it out of that bug,you need to disconnect it first,and reconnect again.
  21. The Following 5 Users Say Thank You to simaservis1108 For This Useful Post:
    BradyAus (21st October, 2018), cocutanu (12th January, 2015), jaelgti (13th January, 2015), obdsystems (21st June, 2015), sv2hqx (12th January, 2015)
