Hi DK people.. i make reflash xprog v5 with ponyprog! i make self adapter with 4 resistor 330ohm. its work super. i put here schematic for adapter. Make all 330ohm resistor.not 100ohm like in picture. Work good. VCC 5V i put via usb xprog.
Config file with lockbits and fusebits for xprogm project(when someone update/repair xprogm with another xprogm). Choose in xprogm Project, File and set flash and eeprom from adam28 and this cfg file.
cfg.rar
Hello i have used Usbasp to flash the atmega and Khazama software but i get device is silent,does it need to convert the binary files to hex?
I first flash atmega then eeprom and then lock bit fuses last fuse bits.
I get verify correct but when i open xprog 5.51 i can't update
What i am doing wrong?
I am having the same problem.. flashed with another xprog and also ponyprog but still getting "device silent" Error no light lighting up on xprog either... Tried a 5.0 flash but still the same.. every thing verifies fine... once lock bits done then verifies wrong... cant see what i am doing wrong... programmer was faulty prior to flashing but cant remember what was wrong.. think it wasn't reading anything but think led was lighting.. any help work by great...
Another thing that i notice is that the xprog sowftare find the device like xprog com 2 compare to the video that upload it that is writing also the (xprog-m).
Maybe the fdti eeprom is different,in mine is blank can somebody upload the fdti eeprom file?
i tried to read atmega mcu with orange 5 but always i get FF as answer
I'm just wondering if the above issues are programming errors caused by incorrect connections to the Atmega. I've not yet heard mention of grounding (during programming) the pin between the normal GND and MOSI pins but it does apparently need it.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Found Fault..
Make Sure To Disconnect From Programmer ..
The 2 GND pins being shorted together stops the Atmega from functioning.
DOH...
Had Another problem getting it to update kept showing hardware as "------------" but tried differant computers and differant usb lead and low and behold it all worked..
So have now updated my other Xprog with no problems what so ever...
Cheers and i hope my experience has helps someone else..
I have successfully update the xprog 5.00 to 5.51 but i found another problem,all authorization is enable but when i try to read a secured MC9S12XS128 mcu i get this error.Anybody know anything about this?
To UNOFEAR
Look at post 43 in this thread - see foto in line 9s12xs security - no authorization data ?
I post in this thread by serg2000 http://www.digital-kaos.co.uk/forums...-Box551/page27
post 393 but no one answer.
in china ver. 5.55 is new one like this http://www.alibaba.com/product-detai...137709879.html
I can`t see this authorization too (0024-5)
I have on 9s12b
Not tried to xs
Sent from my Optimus 4X HD using Tapatalk
I am sure everybody will have the same problem after xs128 authorization doesn't have date like the others
Read of external eeprom if needed.I`d read xprog m eeprom by UPAupa ori 93c46.rar
andrzejopel13 (6th April, 2015), jakesman (9th October, 2016), kostelectronics (29th October, 2018), MAYQUAD (8th February, 2015), mohamedkey (11th June, 2015)
