I updated ok, but tried to read Mercedes Benz EZS w211, w209 with 912 processors and fails to read, any solution please???
Hi all
I have an xprog m v 50 and i tried to update it and i failed
I have bought a tl866a and s51&avr with extreme burner
I changed the atmega64a and tried to program it with usbasp s51&avr it always say error
Usbasp found on port but power on failed
So i changed to tl866a but with it i can read the atmega and erase it say succeful but when i want to program it says error adress 0x00000 buf val 0x0c ic val 0xff
And also when check the id it says ff ff ff
If any one can advise i will be appreciate
Usbasp work fine with xprog, bat need powered xprog. If you necesary i have(in other laptop) .hex .epp and fuses for Extreem Burner.
Hi thanks for your reply
Yes i need them
If you can post them i will be thankfull
Do i need to put 12 v power to xprog
can we use ponyprog to flash Atmega?
ammarben (8th June, 2015)
I have updated from v5.0 to xprog 5.5.1, all ICs are authorised,
i have this Errors,Unknown cammand Saftware error.
can you post how you flash with ponyprog?
pony prog Read Security and Configuration bits and cable schema
chema for pony prog
Hi.Some members asking for Flashing using TL866.I found this somwhere and it works for me.BR
Please dear members push the button if my work was helpfull!
And reputation button(star)
giovani (16th June, 2016), jakesman (2nd August, 2015), milerk (18th July, 2018), paulocesar (28th June, 2016), t1tan1 (30th August, 2015)
Thank you very Much!!! Great Work!
