Page 3 of 15 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 218
  1. #31
    Top Poster + dom8's Avatar
    Nov 2012
    Baltic states
    Quote Originally Posted by 2xded View Post
    Yes, use in-circuit connection.
    my tl866 not have isp
  2. #32
    miha99's Avatar
    Sep 2009
    EU
    Yes because TL866 is produced in two options - with and without isp
  3. #33
    ttzag's Avatar
    Jun 2010
    digital-kaos
    Is it working with orange 5 ?
    Any one know the diagram please?
    Mine is xprog box
    Thanx in advanced
    sent from LG_G2
    Actions speak louder than words
  4. #34
    Oct 2012
    Hi all friend
    you must programmer step by step ,i used with USB-UPA:
    1. Erase chip atmega 64
    2. Program eeprom , Flash
    3. Set Lock bits and fuse bits. Program lock bits, fuse bits.
    4. Copy Xprogbox 5.51 to C:\ and run Xprognew.reg
    5. Run XprogDesktop.exe and update .
  5. The Following 5 Users Say Thank You to binhminh410 For This Useful Post:
    alle bmw (29th January, 2019), asliyucegsm (25th April, 2015), esobrino9 (29th December, 2020), jaelgti (26th December, 2014), no__name (23rd December, 2014)
  6. #35
    ttzag's Avatar
    Jun 2010
    digital-kaos
    Any one know how to set fuse with orange5?
    sent from LG_G2
  7. #36
    Dec 2010
    Quote Originally Posted by binhminh410 View Post
    i have problem.i have xprog 5.0 clone. i install on win7 x 32bit, adobe reader 10. update ok. run error : unknown command. Software error. How to soved?
    Hello fellow
    merry christmas
    I have the same problem
    I can help
    thx
  8. #37
    gyapi11's Avatar
    Aug 2011
    Hungary
    I reapir my xprog in this way.
    I use UPA-USB Device Programmer v1.2 to repair my xprog
    1. Earse Chip (Atmega64)
    2. Lock Bytes all True Before Programming and fuse bytes like in photo fuse.jpg
    3. Write Flash
    4. Write Eeprom
    5. After write flash and eeprom configurate Lock Bytes see photo lockbytes.jpg
    Merry Christmas
  9. The Following 5 Users Say Thank You to gyapi11 For This Useful Post:
    audiotek (28th December, 2014), BradyAus (21st October, 2018), jaelgti (25th December, 2014), pablobonome (23rd May, 2015), xseva (10th September, 2018)
  10. #38
    Jan 2010
    This can work with atmega128 ,is spoiling my ATmega64.
  11. #39
    atayok's Avatar
    In God We Trust!
    thank you good work
  12. The Following User Says Thank You to atayok For This Useful Post:
    sarigol45 (23rd January, 2017)
  13. #40
    peko's Avatar
    Jan 2010
    i have error during installation software ...
    you must connect xprog to computer before runing soft installation ?
  14. #41
    Apr 2013
    No, the program runs without connection Xprog too.
  15. #42
    ttzag's Avatar
    Jun 2010
    digital-kaos
    I left fuses as it before programming and set locks, working great , thanks adam.
    Test it on cas2 white ,read write eep and flash ok .
    Test it on MC68HC05B6 stock on bypass security!!
  16. The Following User Says Thank You to ttzag For This Useful Post:
    mexanico1971 (20th November, 2022)
  17. #43
    audiotek's Avatar
    May 2011
    Default Xprog 5.0 clone succesfully updated to 5.51
    Thanks Adam, my old xprog-m 5.0 now have the 5.51 version succesfully installed!, I already tested with Infineon xc23xx, Mac7242, SPI, I2C, Microwire eeproms, some 9S12, HC11, HC05 and TMS. Works great, verify error also fixed with update. Before this update I can't read/write the HC05H12, now it's working!. All authorizations activated.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
  18. #44
    Aug 2010
    Polska
    Hello.
    My Xprog not working properly, do not report Hardware ID is ---------------------- and I can not run anything with auth 24.
    Update with version 5.0, was programming ISP mkII several batches and still the same.
    nn.
    no links to members sites in sigs
  19. #45
    Dunker's Avatar
    Yorkshire
    I had the '--------------------' hardware ID when I made the mistake of having the MOSI pin wrongly connected when programming the Atmega64. No errors in programming and no errors when updating the firmware. When I eventually sobered up a bit and connected everything correctly and re-programmed it all worked.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  20. The Following User Says Thank You to Dunker For This Useful Post:
    no__name (31st December, 2014)
