    Default EDC16 C39 DTC remove: P0403 + P2620 + limp mode
    Hi guys,
    Removed throttle and EGR from this car to install a special intake, can anybody help me in removing DTCs and related limp mode?
    DTCs are P0403 and P2620 , and they come with limp mode.
    Thanks much
    1037386724.zip
    Fantomisback's Avatar
    Aug 2012
    Quote Originally Posted by teoturo View Post
    Hi guys,
    Thanks much
    1037386724.zip
    dtc off pass in pm
    DTC are gone, limp mode not. I solved limp mode adding a resistor to emulate EGR valve on plug. If I disconnect EGR (or resistor) I get limp mode with no DTC.
    In any case, could you please delete DTC code P061B ? Car runs perfectly now but sometimes this DTC comes. Ecu is deeply modified with some parts from 1.9jtdm 16v so I'm not so worried about this DTC
    Dec 2013
    here you are no DTC
    you should correct a chs
    pass PM
    But you deleted ALL dtcs ... that's not ideal
    Dec 2013
    I know what I've done
