    Jan 2011
    Lithuania
    Default vw units swapping usig VCDs
    Hello,DK members
    Do anybody can confirm until which year edition of the cars
    VCDS is able to swap engine and immo units,adapt
    a new keys? I cleary know that it's impossible in
    4th generation of immo.But,does it's possible on 3th generation?
    What differences between
    original and clone tools in this procedures?
    Thank you
    Ireland
    Cant be answered that simply.
    What exactly are you trying to do?
  3. The Following User Says Thank You to sherl645 For This Useful Post:
    art64 (11th December, 2014)
    DK Veteran teuton's Avatar
    Mexico
    Quote Originally Posted by art64 View Post
    Hello,DK members
    Thank you
    1- If you got an IMMO IV (challenge) that is pre-micronas you can swap these units.That would be early 2006 (06/2006). Anyhow, you'll needthe pincodes of both, old and new.
    On micronas units you'll be dealing with CS and that's a different story....
    2- If your clone cable works then there si no difference in the procedure.
    BR
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  5. The Following User Says Thank You to teuton For This Useful Post:
  6. #4
    Jan 2011
    Lithuania
    Quote Originally Posted by sherl645 View Post
    Thank you for reply
    It's interesting me at all. In past i was trying to swap the engine's ECU and dash,also removing old keys from the dash in immo 4.(5 digits pin in all cases i knew) Without success . It wasn't surprise for me because I heard VCDS not doing this. But yesterday I didn't swap immo3,so it looks strange for me.
    Teuton, I misunderstood which device you using then dealing with CS in micronas cases?
    Mexico
    Here are the ross-tech links that might help you:
    Immobilizer IV ECU Swapping - Ross-Tech Wiki
    Immobilizer - Ross-Tech Wiki
    The CS data you will need when making a key. The easiest (not cheapest) way is the AVDI. Another possibility is reading the dash with x.prog or km+immo tool and then prepare the transponder with tango.
    BR.
  8. #6
    Jan 2011
    Lithuania
    Yesterday I did return to this work (swapping ECU and dash in immo 3 system) And did it from the first attempt. So ,now I know: my chinese cable 12.10 is bad in this procedure. yesterday, I took old a little bit damaged cable 8.14 and did it simply. The old true - The cheap thing can't be good And what about the original cable? Until which year edition of the cars the original cable can swap units,adapt the keys?
