Results 1 to 15 of 16
    Jun 2008
    Default bit lost.. not sure where to go now!!
    Hi guys.. im a bit a lost now.. ive put an image on and copied the cables.xml file on.. ive also done a brute force and after the transponder scan i just dont know what to do.. i know i need to install evocam using the blue button.. but i just cant seem to get anything working..
    anyone care to help me...
    Jun 2008
    If the blue button option is not working You will need to FTP to your dreambox m8, get the ip addy from the boxes settings page set up flash-fxp (or your own ftp proggy) then send over the relavent cams/key* and that should sort it.
    Jun 2008
    scrap that.. i got it working.. forgot to set evocamd as the default cam..
    all seems to be working.. yipeeeeeeeee...
    another quick question though.. is there anyway to sort the arrangements of the channels somehow.. they all seemed jumbled up..
    also do i need to save the settings somewhere as i turned the box off and lost all the channels..
    also (last one i promise) where do i put the picon folder..
    Jun 2008
    Quote Originally Posted by faddy View Post
    Use dreamboxedit (available in the downloads section). Download channels to your pc, sort them and then load them back to you dreambox
    Did you chmod the attributes on keylist.txt to 755
    I think this depends on the image. Try searching for a directory with picon in the name.
    Out of interest, what image are you using?
    Last edited by mjjr; 21st June, 2008 at 11:03 PM. Reason: Corrected Chmod attribute
    Jun 2008
    many thanks for your reply..
    i tried dreamboxedit.. seems like a great programme to use.. however the changes i make on dreamboxedit dont seem to save.. any ideas.. are there any attributes that i need to change on the dreambox..
    which leaves me to chmoding the file.. where is the keylist.txt file located..
    im using a pli image.. is there any others which are better than this.. it seems pretty decent..
    Jun 2008
    Default Basics of how to use Dreambox Edit
    To use dreamboxedit:-
    1) Open the options button (also under tools menu), select the profile tab & then type in the IP address of your dreambox & save
    2) Create a directory on your pc to store the services and bouquets.
    3) Click on the FTP button (also under file menu)
    4) Change the "local directory" to the one you just created on your pc
    5) Now click on "receive files from dreambox" button
    6) Close FTP menu
    7) Create bouquets (in the right box) e.g. Terrestial, Satellite, Sports, etc.
    8) Now select a bouquet in the right box that you want to add some channels to
    9) Drag channels from the left box to the middle box. You can re-order, re-name the channels, etc.
    10) When finished, click File / Save - the files are now saved on your pc (but not on your dreambox).
    11) Go back into the FTP directory and click on "Send files to dreambox"
    12) You now need to click on "Reload settings" button (or simply re-start your dreambox)
    <--mjjr added 17 Minutes and 31 Seconds later...-->
    keylist.txt is in var/keys - it needs execute permission. Check the chmod attribute - it should be 755 (mine is actually 750, but it still works).
    I use a Pli Lolite. The image is very good, but it doesn't have teletext so I'm thinking of changing to something else. Problem is that there aren't many DM600 images out there.
    Jun 2008
    thanks for your post.. ive been playing with dreamboxedit most of the day and i think ive got it to a stage where im happy with it.. just trying to get my head around recording to be honest.. ive been so used to sly+ and im finding it difficult to get my head round the longwinded procedures with this..
    Jun 2008
    Post a reply if you need help
    Jun 2008
    im getting on well with it.. but if anyone can post some tips itll be great..
    Jun 2008
    That's a bit like looking for a needle in a haystack. But if you ask a specific question, you'll get help from someone.
    Mar 2008
    Quote Originally Posted by mjjr View Post
    keylist.txt is not used for saving channel info. It is used by one/some of the emu's but I can't remember which at this time in the morning.
    500c, 600c, 7025+cc, 7000s with a 1m steerable dish
    Jun 2008
    Faddy "lost all the channels" - I think he meant they weren't clearing when he turned on his box. Keylist.txt is used by evocamd to save the key info that's needed when the box is started.
    However if Faddy has to do a complete transponder re-scan to set up all the channels every time, then that's a different problem. This would be unusual - I've never come across it in any of the posts.
  13. #13
    Jun 2008
    All seems to be working fine now thanks.. think it was just me to tell you the truth..
    where are hdd recordings stored.. can i literally just drag up to my pc via ftp and record to dvd..
  14. #14
    V.I.P. Member Curious123's Avatar
    Apr 2008
    If you bring up the channel epg than press the green button you can record automatically. Saves having to type in the start and end end times in the timer recording.
  15. #15
    Jun 2008
    the hdd recordings are stored in the hdd/movie directory.
    The files are stored in a transport stream format (*.ts). To play back on a pc use VLC VLC media player - Overview
    To save to a dvd use DVR Studio Pro from http://www.haenlein-software.com. You can download a 30 day trial. Alternatively use DVR Studio (not the pro version) and your own DVD authoring software.
    Unfortunately I don't know of any free alternatives to DVR Studio Pro......
