this is screen shot of device manager
I dont do Teamview - or anything like it to be fair. All files including J-Link firmware and drivers are posted in this thread. Just follow my instructions above. It is all pretty simple. If you are struggling with this I'd be careful of using the J-Link on anything expensive, it can brick things it is connected to...
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Thats exactly what I had. Windows has picked the wrong driver instance. I deleted the driver, scanned for new hardware again and then manually chose the driver to install.
I have deleted th driver and reinstalled it and it came up in usb not at port section again, now when i did all i could and i launch the jlink configurator at the process to click on update firmware, it report that my device is CLONE, even though i am doing this offline... please what should i do, i try to ignor the message and click on update but during the update the software close.
am flashing with de file in page 1
vari (20th July, 2018)
friend dies Segger correction I tried running
J-Link you do use it with orginale
asliyucegsm and cars repair and notebook chipset repair
here is the status of my clone which software detect as clone
Your firmware string looks wrong in your commander screenshot. Maybe sort that first with a hex editor. Also, if have you definitely updated your J-Link with configurator before entering your serial number with commander it should be ok. If you update firmware with anything above 4.84 using commander as opposed to configurator it will fail.
The firmware in the post above looks unmodified according to the info in the sonsivri and dfrobot threads (bytes above the features string location are not FF'd out). Mine are but if they work for you - crack on.
There is obviously something in the > 4.96m dll that checks something we havent seen. Need to cut back on the beer and find it... Or even, extract the proper firmware from the dll and use that instead. Unless it is just a serial number issue after all...
forumoto (8th May, 2015)
I have use asliyucegsm firmware posted and had the above screen gui window screen shot posted above, i want to know if the above window image look okay, how do i test the device to be sure it can work now....
Your commander screenshot looks like the firmware from post #8. The asliyucegsm firmware has GDBFULL not GDBFull in its features string. Your J-Flash screenshot must be usung the latter. No matter. If commander and J-Flash work now without any clone issue then it should work. Just find a board with a chip that is supported by the J-Link, do some reading and connect up. BTW both firmwares are the same, the only differences are the bytes you should be altering yourself anyway.
forumoto (9th May, 2015)
what could be the reason why this error comes when i try to connect to the device, please help
this message comes, when for example, i pick a flash file from open it to the platform and click on target ---> connect, this message will come and as it appear, means it wont work on flashing device, this has being my issue for long
We have all had this error a million times. Need details of target first.
Hi friends, How are you? does SIGGER JLINKV8 has upgrade in 2016?
Guys, do you have good working firmware with good SN for v8?. Please upload for me
Anyone knows where can I find segger 4.90? My black brick is V8, I'm new one here. Serial is ok after exec command. I just need use as SPI reader/writer (sdmmc). Any suggestion?
