Results 1 to 1 of 1
    Default Skoda octavia engine controll module flash programing
    Hi friends
    I need your help to make Flash programing with ODIS engineer for
    Skoda Octavia
    2011
    engine type CAYC
    VAG no 03L 906 023 LP
    when I select the flash I have an error that ( In the selected flash container : no valid flash session could be determined for the basic variant use ) and the start flashing icon did not changed any idea will be accepted
    I attached picture for the error and the type of files
    the car problem is the DPF light always on and there is no trouble code in engine ecu
