Here is your file corrected.
03g906016dh rafa_HOT_START_CORRECTED.rar
Remember press thanks if I help you.
Hello
I try to write with galletto and not posible,read ok without problem, but when try to write new file mod, galletto closed aplication, try with original avdi and identical ,not begin to write, and close avdi. very rare, I write in all edc16 ecus by obd with original avdi.
the next question
if open the edc16u1 and write by bdm can use the mod file in the second post e read by obd ,or need read bdm flash and make a new mod file from the bdm read? , when write by bdm this edc16 units need correct the checksum before write?
best regarsd and very thanks to all menber
the file from chiptuner8 is not from your car mate...for this you can not write by obd...don"t write this file...i do in a few moments a good file for you,a mod file from your original file...will be without password to understand and chiptuner 8 where is mistake...regards
audiomeca (16th December, 2014)
very thanks friend, I try tomorow and report
best regards
Hello, today tested and perfect!!! very thanks BETRESCUDAN
betrescudan (17th December, 2014)
Yes Betrescudian, i do it in other file where i was working. Sorry audiomeca, was my fail.
