Page 1 of 5 12345 LastLast
Results 1 to 15 of 71
    Lithuania
    Default K tag clone problem
    Hi, I just received clone Ktag, but it dont work. All cars in list grey... not active also not active PROTOCOL button. Tried 2.06 , 2,07 soft, all the same.
    Does there problem if it was connected to internet for couple minnutes ???
    heteromies
    Guest
    Quote Originally Posted by darius89 View Post
    Click info -button and take photo and send here. There is possible tool is blocked if connected to internet.
    prusony's Avatar
    Belarus
    Read flash inside unit and put here.
    Non ut edam vivo, sed ut vivam edo.
    Lithuania
    You mean flash card data ?
    Jul 2011
    Blocked, should never go online with these clones.
    Lithuania
    does possible to fix ?
    Jul 2011
    This tool has been blocked online for sure. You can check if the NXP is locked, I'm sure it will be. I think you need to change the chip and re flash firmware.
    imcumen's Avatar
    Feb 2009
    FRANCE
    Yes jlink+new NXP+firmware https://www.youtube.com/watch?v=lN8V2htDNi0
    but first check the SD card
    I had the same problem I solved
    seeks on the DK forum SDcard file for Ktag
  9. The Following User Says Thank You to imcumen For This Useful Post:
    pataroucci (3rd April, 2015)
  10. #9
    heteromies
    Guest
    Not blocked, my opinion. So maybe broblems are in SD card files.
  11. The Following User Says Thank You to heteromies For This Useful Post:
    prusony (18th December, 2014)
  12. #10
    imcumen's Avatar
    Feb 2009
    FRANCE
    look here for sdcard file for ktag by Zohar
    http://www.digital-kaos.co.uk/forums...n-here-454360/
  13. #11
    korrni's Avatar
    UE
    Hello there, did you manage to solve the problem? Many thanks!!
  14. #12
    korrni's Avatar
    UE
    Hello there, I've had the same problem, all options were greyed out and unselectable, but I've managed to write the NXP using J-Link and now it works , please let me know if you need it! Regards!
  15. #13
    Lithuania
    Rewrited data in card , but didnt help. Please KORRNI Need help with rewriting.
  16. #14
    korrni's Avatar
    UE
    Do you have J-link? Tomorrow morning I'll post the flash file, I'm out of the office! Greetings!
  17. #15
    Lithuania
    Hi, yes i have j-link but dont have any connecting instructions.
    Thanks.
