Any advice or any tips on thione ? Thanks
Hy all DK members,
I just need a bit of help here , car is 2005 Mercedes CLK 270 and the problem is limp mode caused by inlet port shut off valve.
p1189 inlet port shut off
Thank you in advantage & enjoy the holidays to come ,
Best regards, John
swirl flap removal_edc15c6.rar
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
At least somebody can delete the fault code ? P1189
UP bump! any light on this?
give me a minute i do it for you
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
try this out ....dtc off
bursuc (19th December, 2014)
How is dtc removal going to stop limp mode ??????????????
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
We did DTC off and worked, and removed flaps no limp.
But yes DTC wont remove limp, ist there any other method except DTC off ?
is there any possibility to give me original file of ecu?
Andrik at first post you have file without removed swirl..
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
thank you very much/
