Page 4 of 11 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 161
  1. #46
    May 2011
    Agree ,no one will answer our question if we faced issue on MMCflasher , experienced it before , Email no reply
  2. #47
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    Quote Originally Posted by neonlee View Post
    For sorry i had made an order since 10 days ago from ecutools.ru i wish i didi not made this order.......every time i try to search for mmc help files to understand how it works i did not found any info. AND all people who talk about mmc flash talking in russian
    Sent from my SM-T111 using Tapatalk
  3. #48
    DK Veteran Amine13's Avatar
    Hello Guys,
    Well, I don't deny that I haven't read all the posts, however, I would like to know, any link to purchase the MMCflasher, (if allowed here), all the best.
    Just start, and all come itself!!!!!!!
  4. #49
    Oct 2010
    Hi all memebers!
    Sorry for latest reply...
    original MMCFlasher only on this site (site of developer) - mmcflash.ru
    thread for English users on the MMCFlash forum - http://mmcflash.ru/forum/index.php?showforum=9
    Please send all your questions about work of software on the no addys !!!
    also you can ask me about product in PM or Skype
    Notice: MMCFlasher dont have clones. MMCFlasher2 is another product from other developer and most of functions of MMCFlasher2 not work well. Also MMcFlasher2 sells on many chinese sites.....
    BR
    Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
  5. #50
    Oct 2015
    thailand
    Isuzu can transtron sh7058 mmc flasher can read and write????
  6. #51
    Oct 2010
    Cant read and write.
    BR
  7. #52
    Oct 2010
    NEWS!
    New module has been released - Module 30 - Honda K-line
    Module allows only writing ECUs for old Honda/Acura (with K-line) cars:
    Accord7/TSX 03'-07' ECU 7055 [512]K Matsu~~~~a 37805-RBA-Xxxx; 37805-RBB-Xxxx
    Accord7 05'-07' ECU 7058[1024]K Keihin 37805-RAD-Xxxx
    TSX 2006 ECU 7058[1024]K Matsu~~~~a 37805-RBA-Xxxx
    Legend/CR-V 02'-07' ECU 7058[1024]K Keihin 37805-RJA-Xxxx;37805-PPA-Xxxx; 37805-PNL-Xxxx
    Fit/Jazz/Airwave 01'-07' ECU L66Q592 [256]K Keihin - test!
    MDX 03'-07' ECU 7055 [512]K Motorola 37805-RDJ-Xxxx
    The base of original firmwares (.BIN) in complect.
  8. The Following User Says Thank You to Zohar For This Useful Post:
    PremierD (12th February, 2016)
  9. #53
    Caribbean
    is the old civic with keihin ecu supported?
    37820-pra-e13
    l66q592 mcu
  10. #54
    Oct 2010
    OKI l66q592 MCU in testing stage. Will be supported in future.
  11. The Following User Says Thank You to Zohar For This Useful Post:
    PremierD (15th February, 2016)
  12. #55
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Does it work with cantiecar and openport 1.3 activation?
  13. #56
    Oct 2010
    Not tested with cantiecar and OP 1.3 (may will work with OP 1.3, but only for some ECUs with K-Line and with manual boot pin).
    Better use with OP 2.0, Mangoose or Cardaq
    BR
  14. #57
    Faraday's Avatar
    May 2012
    Cantiecar is fully compatible with J2534 will it work?
  15. #58
    Oct 2010
    Not tested with this interface, but should work (if fully compatible with J2534 standart).
    BR
  16. The Following User Says Thank You to Zohar For This Useful Post:
    Faraday (23rd February, 2016)
  17. #59
    DK Veteran elecautocr's Avatar
    Quote Originally Posted by Zohar View Post
    Good news!
    Programming of Toyota/Lexus Denso ECUs will be added soon.
    Also will be added new program shell with user friendly interface and new design.
    BR
    Any news about Toyota ??
  18. #60
    Oct 2010
    Toyota in testing, we have some problems.. i hope, we will fix it soon.
    But i have some good news. 2 new modules has been added.
    1st - Module 45 MMCFlasher - Subaru Denso ECUs K-Line + CAN (SH7055, SH7058, SH72531)
    Module 45 MMCFlasher allow reading and writing Subaru cars with ECU Denso (K-Line and CAN bus) with MCU Renesas SH7055, SH7058, SH72531. Module allow reading and writing flash of MCU, checking and correction of checksumms is available. Also module can read/erase DTC in ECU. Reading and writing firmware allowed on the car via OBD2 connection. Module can work with Subaru JDM (Japan Domestic Market) cars with ECU Denso.
    Supported MCUs (for Denso ECUs):
    SH72531 [1280k] CAN 2013+ (Subaru Forester 2013+, Subaru BRZ)
    SH7058 [1024k] CAN 2007+
    SH7058 [1024k] K-line 2003+
    SH7055 [512K] K-line
    SH7055 JDM [512K] K-line
    2nd - Module 47 MMCFlasher - Ford USA cars with ECUs: M799G, PCM170F, PCM190F, MEG9.8.1)
    Module 47 MMCFlasher allow reading and writing Ford USA cars with ECUs M799G, PCM170F, PCM190F, MEG9.8.1. Module allow reading and writing flash of MCU, correction of checksumms will be added soon. Also module can read/erase DTC in ECU. Reading and writing firmware allowed on the car via OBD2 connection. Module will automaticaly recognize size of firmware in used ECU (very convenient function for user). New ECUs will be added soon.
    BR
  19. The Following User Says Thank You to Zohar For This Useful Post:
    PremierD (28th March, 2016)
