Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 76 to 90 of 161
  1. #76
    Sep 2013
    CAMBODIA
    Module 49 MMCFlasher - Ford with ECU SID208 / SID209
    Module 49 MMCFlasher - Ford with ECU SID208 / SID209. Module for programming (reading and writing) Ford protected ECUs SID208 / SID209 (diesel cars). Unlock ECU (reading TPROT) password in boot mode. Checksums calculation is supported. Also supported virtual reading directly from Ford server and convertation from VBF to BIN format. Programming through OBD2 or BSL mode.
    Please help me How to use this model ? thanks
  2. #77
    Oct 2010
    Not tested with this ECU. Need know MCU type exactly. Plaz share photos of PCB.
    BR
    Quote Originally Posted by dairuszl View Post
    What about MMC Flasher support for Melco F8TJ ECU (looks like this -> http://i.ebayimg.com/images/g/Fd8AAO...0g/s-l1600.jpg) ?
    I do not have exact ECU model used inside but this ECU is generally used in new Ducati bikes (Panigale, Diavel, Multistrada, Monster 1200 itp) with slighty different CPU inside. But AFAIK Diavel i Multistrada1200 both use the same ECU.
    Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
  3. #78
    Oct 2010
    BSL mode needed for unlock ECU, also for reading flash.
    Writing possible through OBD2.
    When you purchase module we will send you all nedded information.
    BR
    Quote Originally Posted by CLK1201 View Post
  4. #79
    Oct 2010
    New module has been added:
    MMCFlasher module 56: VAG UDS petrol/diesel MEDC17
    supported ECUs ME(D)17.1/17.5/17.1.1/17.1.6/17.5.5/17.5.20/17.5.21/17.5.22/17.5.24/17.5.25/17.5.26/EDC17C46/C54/С64/СР04/СР14/CP20/СР24/CP44
    Module can write flash memory of VAG (VW, AUDI, SKODA and SEAT) cars with MED/EDC17xxx (UDS) ECUs from list via OBD connectuon in car. Virtual reading is supported directly from MMCFlasher software from server. CS (and RSA) calculation is supported. Also can read/erase DTC in ECM. Module is fully safe in usage. If programming will be interrupted on any step you can continue without afraid to damage ECU.
    List of tested softwares (1109 softwares, 2155 calibration) :
    EDC17C46 (2.0L R4 TDI, 2.0L R4 EDC)
    03L906018AB,03L906018AB,03L906018AC,03L906018AD,03 L906018AE,03L906018AG,03L906018AH,03L906018AJ,03L9 06018AK,03L906018AL,03L906018AM,03L906018AN,03L906 018AQ,03L906018AR,03L906018AS,03L906018AT,03L90601 8A,03L906018BA,03L906018BB,03L906018BC,03L906018BD ,03L906018BE,03L906018BF,03L906018BG,03L906018BH,0 3L906018BJ,03L906018BK,03L906018BL,03L906018BM,03L 906018BN,03L906018BP,03L906018BQ,03L906018BR,03L90 6018CA,03L906018CD,03L906018CF,03L906018CG,03L9060 18CH,03L906018CJ,03L906018CK,03L906018CM,03L906018 CN,03L906018CP,03L906018CQ,03L906018CR,03L906018CT ,03L906018C,03L906018DA,03L906018DB,03L906018DC,03 L906018DD,03L906018DE,03L906018DG,03L906018DH,03L9 06018DN,03L906018DR,03L906018EA,03L906018EB,03L906 018EE,03L906018EF,03L906018EG,03L906018EH,03L90601 8EJ,03L906018EK,03L906018EN,03L906018ET,03L906018E ,03L906018FA,03L906018FC,03L906018FE,03L906018FF,0 3L906018FJ,03L906018FK,03L906018FL,03L906018FM,03L 906018FQ,03L906018FR,03L906018FS,03L906018FT,03L90 6018F,03L906018GA,03L906018GB,03L906018GC,03L90601 8GD,03L906018GE,03L906018GF,03L906018GG,03L906018G H,03L906018GJ,03L906018GM,03L906018GN,03L906018GT, 03L906018G,03L906018HA,03L906018HC,03L906018HD,03L 906018HE,03L906018HF,03L906018HG,03L906018HH,03L90 6018HJ,03L906018HK,03L906018HL,03L906018HM,03L9060 18HN,03L906018HR,03L906018HS,03L906018HT,03L906018 H,03L906018JA,03L906018JB,03L906018JC,03L906018JD, 03L906018JF,03L906018JG,03L906018JH,03L906018JJ,03 L906018JK,03L906018JL,03L906018JM,03L906018JN,03L9 06018JP,03L906018JR,03L906018JT,03L906018J,03L9060 18KC,03L906018KD,03L906018KJ,03L906018KK,03L906018 KL,03L906018KM,03L906018KN,03L906018KQ,03L906018KR ,03L906018KS,03L906018KT,03L906018K,03L906018LA,03 L906018LB,03L906018LC,03L906018LD,03L906018LE,03L9 06018LF,03L906018LG,03L906018LH,03L906018LJ,03L906 018LK,03L906018LL,03L906018LM,03L906018LN,03L90601 8LP,03L906018LR,03L906018LS,03L906018L,03L906018MC ,03L906018ME,03L906018MF,03L906018MG,03L906018MH,0 3L906018MJ,03L906018MK,03L906018ML,03L906018MM,03L 906018MN,03L906018MP,03L906018MQ,03L906018MR,03L90 6018MS,03L906018MT,03L906018M,03L906018NA,03L90601 8NB,03L906018NC,03L906018ND,03L906018NE,03L906018N F,03L906018NG,03L906018NH,03L906018NJ,03L906018NK, 03L906018NL,03L906018NM,03L906018NN,03L906018NP,03 L906018NQ,03L906018NR,03L906018NT,03L906018N,03L90 6018PA,03L906018PB,03L906018PC,03L906018PD,03L9060 18PF,03L906018PG,03L906018PH,03L906018PN,03L906018 PP,03L906018PQ,03L906018PR,03L906018PS,03L906018PT ,03L906018P,03L906018QA,03L906018QB,03L906018QC,03 L906018QD,03L906018QE,03L906018QF,03L906018QG,03L9 06018QJ,03L906018QK,03L906018QL,03L906018QM,03L906 018QN,03L906018QP,03L906018QR,03L906018QT,03L90601 8RA,03L906018RB,03L906018RD,03L906018RE,03L906018R G,03L906018RJ,03L906018RK,03L906018RL,03L906018RM, 03L906018RP,03L906018RT,03L906018SB,03L906018SC,03 L906018SF,03L906018SG,03L906018SH,03L906018SJ,03L9 06018SK,03L906018SL,03L906018SM,03L906018SN,03L906 018SP,03L906018SR,03L906018TA,03L906018TF,03L90601 8,03L997018,03L997264M,03L997264N,03L997264P
    EDC17C54 (2.0L R4 EDC)
    03L906012AA,03L906012AA,03L906012AB,03L906012AC,03 L906012AD,03L906012AE,03L906012AF,03L906012AG,03L9 06012AH,03L906012AJ,03L906012AK,03L906012AM,03L906 012AQ,03L906012AS,03L906012AT,03L906012A,03L906012 BA,03L906012BB,03L906012BC,03L906012BE,03L906012BG ,03L906012BH,03L906012BK,03L906012BL,03L906012BM,0 3L906012BN,03L906012BP,03L906012BR,03L906012BS,03L 906012BT,03L906012B,03L906012CA,03L906012CB,03L906 012CC,03L906012CD,03L906012CG,03L906012CH,03L90601 2CJ,03L906012CK,03L906012CL,03L906012CT,03L906012C ,03L906012DB,03L906012DC,03L906012DD,03L906012DE,0 3L906012DF,03L906012DJ,03L906012DK,03L906012D,03L9 06012ET,03L906012FA,03L906012FB,03L906012FC,03L906 012FD,03L906012FE,03L906012FF,03L906012FG,03L90601 2F,03L906012GQ,03L906012GR,03L906012G,03L906012J,0 3L906012K,03L906012L,03L906012M,03L906012P,03L9060 12Q,03L906012R,03L906012S,03L906012T,03L906012,03L 997009F,03L997403A,03L997403B,03L997403C,03L997403 D,03L997403E,03L997403F,03L997403G,03L997403H,03L9 97403J,03L997403K,03L997403L,03L997403M,03L997403N ,03L997403P,03L997403Q,03L997403R,03L997403S,03L99 7403
    EDC17C64 (0.8L R2 EDC, 1.6L R4 EDC, 1.6L R4 TDI, 2.0L R4 EDC, 2.0L R4 BTD, 2.0L R4 TDI)
    03L906021A,03L906021A,03L906021B,03L906021C,03L906 021,03L997009G,04F906021A,04L906016AD,04L906016AE, 04L906016AF,04L906016AG,04L906016AH,04L906016AJ,04 L906016AK,04L906016A,04L906016BC,04L906016BD,04L90 6016BE,04L906016BF,04L906016BG,04L906016BH,04L9060 16BQ,04L906016B,04L906016CA,04L906016CB,04L906016C C,04L906016CD,04L906016CF,04L906016CL,04L906016CM, 04L906016CN,04L906016CP,04L906016C,04L906016DG,04L 906016DH,04L906016DJ,04L906016DN,04L906016DP,04L90 6016DQ,04L906016DR,04L906016DS,04L906016DT,04L9060 16D,04L906016ED,04L906016EE,04L906016EF,04L906016E G,04L906016EH,04L906016EJ,04L906016EK,04L906016EL, 04L906016EM,04L906016EN,04L906016EP,04L906016EQ,04 L906016ET,04L906016E,04L906016FA,04L906016FB,04L90 6016FC,04L906016FD,04L906016FE,04L906016FF,04L9060 16FH,04L906016FJ,04L906016FK,04L906016FL,04L906016 FM,04L906016FN,04L906016FQ,04L906016FT,04L906016F, 04L906016GA,04L906016GB,04L906016GC,04L906016GD,04 L906016GE,04L906016G,04L906016HL,04L906016HM,04L90 6016HN,04L906016HP,04L906016HQ,04L906016H,04L90601 6J,04L906016K,04L906016MA,04L906016N,04L906016P,04 L906016T,04L906016,04L906021AD,04L906021AE,04L9060 21AH,04L906021AL,04L906021AM,04L906021AN,04L906021 AP,04L906021AQ,04L906021AR,04L906021AS,04L906021BC ,04L906021BD,04L906021BE,04L906021BG,04L906021BH,0 4L906021BK,04L906021BL,04L906021BM,04L906021BQ,04L 906021BS,04L906021BT,04L906021CA,04L906021CB,04L90 6021CC,04L906021CF,04L906021CG,04L906021CK,04L9060 21CL,04L906021C,04L906021DS,04L906021DT,04L906021D ,04L906021EA,04L906021EB,04L906021EC,04L906021EE,0 4L906021EG,04L906021EL,04L906021EM,04L906021EP,04L 906021EQ,04L906021ER,04L906021FD,04L906021FE,04L90 6021FF,04L906021FG,04L906021FH,04L906021FJ,04L9060 21FM,04L906021FN,04L906021FQ,04L906021FR,04L906021 FS,04L906021FT,04L906021M,04L906021N,04L906021P,04 L906021,04L997021D,04L997021H,04L997021,04L997022A
    EDC17CP44 (3.0L BTD, 3.0L TDI, 4.2L TDI)
    4G0907311B,4G0907311D,4G0907311E,4G0907311G,4G0907 401AA,4G0907401D,4G0907401F,4G0907401N,4G0907401P, 4G0907401Q,4G0907401R,4G0907401S,4G0907589A,4G0907 589C,4G0907589D,4G0907589E,4G0907589F,4G1907401C,4 G1907401,4H0907311,4H0907401A,4H0907401B,4H0907401 E,4H0907401F,4H0907401N,4H0907401P,4H0907401,4H090 7409AA,4H0907409AB,4H0907409AD,4H0907409K,4L091040 9H,4L0910409J,4L0910409P,4L0910409Q,4L0910409T,4L1 910401H,4L1910401J,4L1910401L,4L1910401M,4L1910401 P,4L1910401Q,4L1910401S,4L1910401T,4L2910401A,4L29 10401B,4L2910401C,4L2910401E,4L2910401,7P0907311A, 7P0907311B,7P0907311C,7P0907311D,7P0907311E,7P0907 311,7P0907401B,7P0907401C,7P0907401F,7P0907401G,7P 0907401H,7P0907401J,7P0907401K,7P0907401,7P0907409 B,7P0907409G,7P0907409J,7P0907409K,7P0907409L,7P09 07409M,7P0907409N,7P0907409P,7P0907409Q,7P0907409R ,7P0907409S,7P0907409T,7P0907409,7P1907311A,7P1907 311,7P1907401C,7P1907401D,7P1907401E,7P1907401F,7P 1907401,7P1907409A,7P1907409,8K5907311A,8K5907311, 8K5907401AA,8K5907401AC,8K5907401AD,8K5907401G,8K5 907401J,8K5907401L,8K5907401Q,8K5907401T,8K5907401 ,8K5907589B,8K5907589C,8K5907589
    ME(D)17.5.20 (1.0L R3 CPI, 1.0L R3 MPI)
    04C906020AA,04C906020AB,04C906020AC,04C906020AJ,04 C906020A,04C906020BK,04C906020BL,04C906020BM,04C90 6020CP,04C906020D,04C906020E,04C906020F,04C906020G ,04C906020H,04C906020J,04C906020K,04C906020L,04C90 6020M,04C906020N,04C906020R,04C906020S,04C906020T, 04C906020
    MED17.1 (2.0L R4 TFSI, 2.0L R4/4V TFSI)
    06J906021AC,06J906021AE,4G0907115F,4G0907115H,4G09 07115N,4G0907115P,4G0907115,8K2907115AA,8K2907115A D,8K2907115AE,8K2907115AF,8K2907115AG,8K2907115AH, 8K2907115AJ,8K2907115AL,8K2907115AM,8K2907115F,8K2 907115J,8K2907115L,8K2907115P,8K2907115Q,8K2907115 S,8K2907115T,8K5907115A,8K5907115C,8K5907115F,8K59 07115H,8K5907115J,8K5907115M,8K5907115N,8K5907115P ,8K5907115Q,8K5907115,8R0907115A,8R0907115B,8R0907 115C,8R0907115D,8R0907115H,8R0907115J,8R0907115K,8 R0907115P,8R0907115Q,8R0907115R,8R1907115B,8R19071 15L,8R1907115N
    MED17.1.1 (2.0L R4/4V TFSI, 2.5L R4/4V TFSI, 4.0L V8 TFSI/4V, 4.2L V8/4V, 4.2L V8HDZ/4V)
    07V906018A,07V906018B,07V906018C,07V906018E,07V906 018F,07V906018G,07V906018H,07V906018J,07V906018K,0 7V906018M,07V906018P,07V906018,3W0906560A,3W090656 0B,3W0906560C,3W0906560D,3W0906560E,3W0906560F,3W0 906560,3W0907560,4G0906014A,4G0906014B,4G0906014C, 4G0906014E,4G0906014F,4G0906014,4G0906560A,4G09065 60B,4G0906560F,4G0906560,4G0907115D,4H0906014A,4H0 906014B,4H0906014C,4H0906014D,4H0906014G,4H0906014 H,4H0906014J,4H0906014L,4H0906014M,4H0906014,4H090 7115A,4H0907115B,4H0907557A,4H0907557B,4H0907557C, 4H0907557D,4H0907557E,4H0907557G,4H0907557,4H09075 60A,4H0907560B,4H0907560C,4H0907560F,4H0907560,4W0 906560A,4W0906560B,4W0906560C,4W0906560D,4W0906560 E,4W0906560F,4W0906560,7P0907560B,8R0907115N,8R190 7115M,8R1907115P,8T1907560B,8T1907560D,8T1907560E, 8T1907560,8T2907560B,8T2907560E,8T2907560F,8T29075 60,8U0907404B,8V0907404
    MED17.1.6 (1.4L TFSI, 3.0L FSI, 3.0L TFS, 3.0L V6h, 3.6L FSI, E-Vehicle, 6.3L FSI W12)
    03C906023A,03H906023AA,03H906023AE,03H906023AF,03H 906023AG,03H906023AH,03H906023AJ,03H906023AN,03H90 6023BF,03H906023BN,03H906023BS,03H906023BT,03H9060 23B,03H906023CD,03H906023E,03H906023L,03H906023M,0 3H906023N,03H906023R,03H997023,04E906023G,04E90602 3,06E906023AA,06E906023AB,06E906023AC,06E906023AD, 06E906023AE,06E906023B,06E906023C,06E906023E,06E90 6023H,06E906023J,06E906023K,06E906023L,06E906023M, 06E906023N,06E906023P,06E906023Q,06E906023S,07C906 023AA,07C906023AB,07C906023AC,07C906023AD,07C90602 3AE,07C906023AF,07C906023AG,07C906023AH,07C906023A M,07C906023AN,07C906023AP,07C906023AQ,07C906023AR, 07C906023AS,07C906023AT,07C906023A,07C906023BA,07C 906023BB,07C906023BF,07C906023BG,07C906023BH,07C90 6023BJ,07C906023BK,07C906023BL,07C906023BM,07C9060 23BN,07C906023BP,07C906023B,07C906023E,07C906023G, 07C906023K,07C906023L,07C906023M,07C906023Q,07C906 023R,07C906023S,07C906023T,07P906023A,07P906023B,0 7P906023D,07P906023E,07P906023F,07P906023J,07P9060 23M,07P906023
    MED17.5 (1.8L R4/4V TFSI)
    8K1907115C,8K1907115C,8K1907115D,8K1907115F,8K1907 115K,8K1907115M
    MED17.5.21 (1.0L R3 TFS, 1.2L R4 TSI, 1.2L R4 TFS, 1.4L R4 TSI, 1.4L TSI CNG, 1.4L R4 TFS, E-Vehicle)
    04C906026AB,04C906026AB,04C906026AH,04C906026AJ,04 C906026AK,04C906026AQ,04C906026C,04C906026Q,04C907 309AL,04E906016AC,04E906016AD,04E906016A,04E906016 BB,04E906016B,04E906016CE,04E906016CF,04E906016CG, 04E906016CH,04E906016CN,04E906016CP,04E906016CR,04 E906016CS,04E906016CT,04E906016C,04E906016DE,04E90 6016DF,04E906016DJ,04E906016DL,04E906016DM,04E9060 16EG,04E906016E,04E906016F,04E906016G,04E906016H,0 4E906016J,04E906016K,04E906016L,04E906016M,04E9060 16N,04E906016Q,04E906016R,04E906016S,04E906016T,04 E906016,04E997016A,04E997016B,04E997016,0EA906016A ,0EA906016B,0EA906016C
    MED17.5.22 (1.6L R4 MPI, 1.6L R4 CPI)
    04E906057A,04E906057B,04E906057C,04E906057D,04E906 057K
    MED17.5.24 (1.0L R3 MPI)
    04C906020AF,04C906020AK,04C906020AL,04C906020AM,04 C906020AN,04C906020AP,04C906020AQ,04C906020BN,04C9 06020BQ,04C906020BR,04C906020BT,04C906020CC,04C906 020CD,04C906020CE,04C906020CF,04C906020CJ,04C90602 0CL,04C906020CN,04C906020CQ,04C906020CT,04C906020D P
    MED17.5.25 (1.2L R4 TSI, 1.2L R4 TFS, 1.4L R4 TSI, 1.4L R4 TFS)
    04E906027AF,04E906027AF,04E906027AG,04E906027AJ,04 E906027AL,04E906027AT,04E906027BB,04E906027BC,04E9 06027BK,04E906027BL,04E906027BR,04E906027BS,04E906 027BT,04E906027CD,04E906027CE,04E906027CH,04E90602 7CK,04E906027CL,04E906027CM,04E906027DA,04E906027D C,04E906027DF,04E906027DG,04E906027DM,04E906027DN, 04E906027DP,04E906027DR,04E906027EF,04E906027EH,04 E906027EK,04E906027EM,04E906027ET,04E906027FK,04E9 06027FL,04E906027F,04E906027GM,04E906027GN,04E9060 27GP,04E906027GQ,04E906027GR,04E906027GS,04E906027 GT,04E906027HB,04E906027HC,04E906027HD,04E906027HE ,04E906027HF,04E906027HG,04E906027HJ,04E906027HK,0 4E906027HL,04E906027HM,04E906027HN,04E906027HQ,04E 906027HR,04E906027JA,04E906027JC,04E906027JD,04E90 6027JL,04E906027JM,04E906027KL,04E997027A
    MED17.5.26 (1.0L R3 MPI, 1.6L R4 MPI)
    04C906057AB,04C906057AD,04C906057A,04C906057L,04C9 06057N,04C906057,04E906057AD,04E906057AF,04E906057 AG,04E906057AH,04E906057AQ,04E906057AR,04E906057CC ,04E906057CD,04E906057CP,04E906057CQ,04E906057DA,0 4E906057DB,04E906057DC,04E906057DD
    MED17.5.5 (1.4L R4 TSI, 1.4L R4/4V TSI, 1.4L R4/4V TFSI)
    03C906016AD,03C906016AP,03C906016BA,03C906016BA,03 C906016BB,03C906016BC,03C906016BC,03C906016BD,03C9 06016BD,03C906016BE,03C906016BE,03C906016BF,03C906 016BF,03C906016BG,03C906016BG,03C906016BG,03C90601 6BH,03C906016BH,03C906016BH,03C906016BK,03C906016B L,03C906016BL,03C906016BL,03C906016BN,03C906016BP, 03C906016BP,03C906016BS,03C906016BS,03C906016BT,03 C906016BT,03C906016CA,03C906016CA,03C906016CD,03C9 06016CD,03C906016CD,03C906016CE,03C906016CE,03C906 016CE,03C906016CG,03C906016CG,03C906016CG,03C90601 6CN,03C906016CQ,03C906016CQ,03C906016CQ,03C906016C R,03C906016DF,03C906016DF,03C906016DG,03C906016DG, 03C906016DG,03C906016DH,03C906016DH,03C906016DH,03 C906016DJ,03C906016DJ,03C906016DJ,03C906016DK,03C9 06016DK,03C906016DL,03C906016DL,03C906016DL,03C906 016DM,03C906016DM,03C906016DP,03C906016DP,03C90601 6DQ,03C906016DT,03C906016EB,03C906016EB,03C906016E C,03C906016EC,03C906016ED,03C906016ED,03C906016EE, 03C906016EF,03C906016EG,03C906016EG,03C906016EH,03 C906016EJ,03C906016EJ,03C906016EK,03C906016EL,03C9 06016EL,03C906016EM,03C906016EM,03C906016EN,03C906 016EN,03C906016ES,03C906016ET,03C906016ET,03C90601 6FB,03C906016FB,03C906016FC,03C906016FC,03C906016F D,03C906016FD,03C906016FE,03C906016FE,03C906016FF, 03C906016FG,03C906016FJ,03C906016FL,03C906016FM,03 C906016FP,03C906016FP,03C906016FR,03C906016GD,03C9 06016GG,03C906016GG,03C906016GH,03C906016GH,03C906 016GJ,03C906016GJ,03C906016GK,03C906016GK,03C90601 6GL,03C906016GL,03C906016GS,03C906026AA,03C906026A F,03C906026AP,03C906026AS,03C906026AS,03C906026AS, 03C906026AS,03C906026AS,03C906026AS,03C906026AT,03 C906026A,03C906026BC,03C906026BC,03C906026BC,03C90 6026BD,03C906026BD,03C906026BM,03C906026BN,03C9060 26BP,03C906026BR,03C906026BR,03C906026BR,03C906026 BR,03C906026BR,03C906026BS,03C906026BS,03C906026BT ,03C906026CA,03C906026CC,03C906026CE,03C906026D,03 C906026F,03C906026G,03C906026J,03C906026K,03C90602 6K,03C906026L,03C906026L,03C906026L,03C906026L,03C 906026P,03C906026Q,03C906027AD,03C906027AD,03C9060 27AD,03C906027AD,03C906027AD,03C906027AD,03C906027 AE,03C906027AE,03C906027AE,03C906027AE,03C906027AE ,03C906027AR,03C906027AR,03C906027AR,03C906027AR,0 3C906027BC,03C906027BD,03C906027BE,03C906027BF,03C 906027BF,03C906027BJ,03C906027CE,03C906027CE,03C90 6027CE,03C906027CF,03C906027CF,03C906027CF,03C9060 27CF,03C906027CF,03C906027CG,03C906027CH,03C906027 CP,03C906027DB,03C906027DC,03C906027DC,03C906027DF ,03C906027DG,03C906027DH,03C906027DM,03C906027D,03 C906027D,03C906027E,03C997016K,03C997016K,03C99701 6K,03C997016L,03C997016L,03C997016L,03C997016M,03C 997016M,03C997016M,03C997017A,03C997017A,03C997017 B
  5. The Following 5 Users Say Thank You to Zohar For This Useful Post:
    eddieddi (7th February, 2017), Faraday (5th December, 2016), pablo1971 (14th April, 2017), PremierD (16th November, 2016), yugo45 (15th January, 2019)
  6. #80
    vw 04l907309d not suported
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  7. #81
    Moderator
    PremierD's Avatar
    Jun 2009
    Where does it say that is is supported mate .....?????
  8. The Following User Says Thank You to PremierD For This Useful Post:
    Zohar (2nd December, 2016)
  9. #82
    Nov 2016
    Hi Zohar, maybe in the future there can be a Sagem module for SH7055 to allow R/W of 512kb. Currently other tools do not see all of the 512kb file (the beginning is missing).
  10. #83
    Oct 2010
    For now Sagem ECUs not supported. May be in future....
    BR
  11. #84
    Member satriawr's Avatar
    Mar 2016
    Jakarta, Indonesia
    This tool able to do toyota 1kd/2kd and 1gd/2gd engine ecu??
  12. #85
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by satriawr View Post
    Toyota menu ........................
  13. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    CarCity (9th December, 2016), mexanico1971 (2nd October, 2018), pablo1971 (13th February, 2017)
  14. #86
    soxten's Avatar
    Mar 2013
    I have mmcflash and OP2.0 with Mitsubishi option.
    but dont understand how to connect ecu on bench....
    Normal on mitsubishi 5-plug is + and - and k-line.
    Then I see that I need 16v for flash....
    And OP2.0 has a special connection in back of obd-comnector.
    In program I can choose boot on pin 12/11/8
    I dont understand, please need help
    Skickat fr?n min iPhone med Tapatalk
  15. The Following User Says Thank You to soxten For This Useful Post:
  16. #87
    Mar 2016
    Jakarta, Indonesia
    Quote Originally Posted by PremierD View Post
    Is that new gen? Old gen only write only,...
  17. #88
    Oct 2010
    Toyota not realeased yet. Module in testing stage.
  18. #89
    Oct 2010
    Hello
    You can you external minijack connector for connecting to boot pin of ECU (+16V) or
    any assigned (in MMCFlasher software) PIN 8/11 or 12 in the OBD connector of Open Port 2.0.
    BR
    Quote Originally Posted by soxten View Post
  19. The Following 2 Users Say Thank You to Zohar For This Useful Post:
    pablo1971 (13th February, 2017), PremierD (20th December, 2016)
  20. #90
    Oct 2010
    No, its old gen. Only writing
    BR
  21. The Following User Says Thank You to Zohar For This Useful Post:
    satriawr (5th January, 2017)
