yes 2 switches. But that only if sensors are ok, conected and working. if sensors are bad it needs DTC delete too!
better disconnect sensors because pressure sensor or faulty in them,just in case if gose in future.
and remove dtc.
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
OK. So please give me a file.
Best regards
Adam
try to get a solution
mellon (21st December, 2014)
Need same car-ecu solutions...please password.
Thanks!
just post your file
its easy to do.
DSG TUNING
File Service
DSG TUNING
File Service
maki (16th March, 2018)
Same problem limit 3000rpm...not have P0603???
Have maybe any other solutions??
Try this......
what is ecu? edc16? c34? c0?
Vasily.U
Thanks friend,
I tested file same -3000rpm,not have any error...before write file I make cks in winols.
